Petrol Question
Iv just changed the petrol tank on my sapphire cosworth, iv put 2 gallons in. The petrol light is still on and the gauge is still in red, is this right? If so how much does it need before light goes out and needle moves?
Gauge and light worked perfect before and iv used the original sender unit.
John.
John.
Originally Posted by R4N S S
i out in 58.76 litres the other day
Wanna be careful doing that mate, don't wanna drag all the shit out of the almost 20 year old tank through the injectors/engine!
I've managed to get over 60 litres in my Sapphire before (without having to push it
). Must have been running on fumes
However, I have always run my cars down to almost empty (with regular fuel filter changes), as I have not wanted to allow the build up of any crap in the bottom of the tank by never allowing it to run low.
.However, I have always run my cars down to almost empty (with regular fuel filter changes), as I have not wanted to allow the build up of any crap in the bottom of the tank by never allowing it to run low.
got there and the fookin petty stn is closed looked at my juice needle and its sitting right at the bottom of empty. Then thought fook putting Superunleaded in, and then i started heading towards Windsor which is the next nearest Shell. Cruised it ever so gently there knowing that if i put my foot down I will not be going anywhere
Put said juice in - then realised I have a water leak from the header tank to turbo hose so had to coast the car back home then - and a fookin Testarossa went flying past me on the test track and i couldnt play due to my leaky hose
Normally out juice in after it drops below qtr tank.
