Head Gasket - which one
Old 03-12-2008 | 01:02 AM
manoj's Avatar
manoj
Default Head Gasket - which one
Hi,
I need some advice on what’s the most reliable option. Fit & forget.
What Head Gasket is recommended for 360/380 bhp, T34, Light Blues, 7.8.1.
a) WRC 4 Layer & 6 Long Studs via Martin/SCS/Rainbird/A1..?
b) Wire Rung 200 block with yb0611 gasket.?
c) Group A HG with Standard Bolts..?
thanks,
Manoj
Old 03-12-2008 | 08:28 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
You will have to take the engine out and strip it if you want to fit long studs. Same applies to wire rung block
You will be fine with a cometic multi-layer/WRC gasket and standard bolts at that power level. Take a look at my resto thread. I am using a cometic one and standard head bolts.
Block and head need to be completely flat if using metal gasket
Old 03-12-2008 | 09:16 AM
Twellsie's Avatar
Twellsie
you dont have to take the engine out to wire ring it, karl at NMS did mine whilst still in the car
01-11-2015 07:53 PM
07-10-2015 01:56 PM
Mc5506
05-10-2015 10:57 PM
DAZZER
30-09-2015 09:43 PM
pie-face
15-09-2015 11:43 AM
