Dyno Dynamics experts please look inside
Old Nov 26, 2008 | 10:00 AM
  #41
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Preferably the graph of his escort which has never been posted on here would be nice
Old Nov 26, 2008 | 10:21 AM
  #42
Chip's Avatar
Chip
*** Sierra RS Custard ***
Stage 3 cossie would be my first choice of graph if I get a choice, as thats a "typical car" where as martin's isnt.
Old Nov 26, 2008 | 10:24 AM
  #43
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Originally Posted by Chip
Martin do you have some graphs to show the IT you get doing it this way mate?
1 at the beginning of a long mapping session and one at the end would be perfect
Yes but I don't have time to print them off, I do know that the difference between the two air temps stays pretty consistant but without the fan on and with the engine idling after a run the IT does rise but quickly comes back down when the fan is back on. I'm doing a load of work on the Escort next week so will let you know how that gets on.
Old Nov 26, 2008 | 10:27 AM
  #44
It's Czech Mate's Avatar
It's Czech Mate
My thoughts would be that the IT probe should be as close to the Airfilter as poss and if the IT probe was massively higher than the AT then the airflow/fan to the rolling road is inadequate
Old Nov 26, 2008 | 10:29 AM
  #45
CossieRich's Avatar
CossieRich
Not sure how many stage 3 cossies require long mapping sessions really. Although that does depend on what you determine long mapping session. Bet martins escort has had a few longish mapping sessions with plenty of data available
Old Nov 26, 2008 | 10:37 AM
  #46
Garage19's Avatar
Garage19
In my opinion the IT probe should not be above the engine bay.
I'm sure Chip mentioned it only takes one reading prior to a run.
The air temp that passes over an air filter during a run will be totally different temp to the air convecting off a warm engine prior to the run.
Old Nov 26, 2008 | 10:52 AM
  #47
dojj's Avatar
dojj
Resident Wrestling Legend
Its supposed to be a measure of the temperature of air going into the air filter.
Where you choose to get a reading from to represent that is a matter of some debate, but not a lot, essentially it needs to be somewhere between the air filter and the dyno wall, where you think it best respresents the actual temperature of air that will go into the air filter, often putting it to close will result in it picking up radiant energy from hot engine components that will make the sensor hot but wont heat up the air going in to the same extent.
Im with Gary in that two far away is better than too close if you have to be either.
On a turbo car, putting it AFTER the turbo is always going to make it think the air coming into the air filter was hotter than it really was as the turbo compresses the air, which heats it up! (pv=nrt)
ok, got that, understood the mechanics behind it, now for a different question
where does the car manegement take it's reading from?
assuming it would be at the same place due to it wanting to know how hot the air was etc if that's one of the paramiters invovled in engine fueling
and
i'm sure i've read on some tests for i/c etc, the air going into the engien is virtually as cold, if not colder, than the ambient before/after
or
is this for rolling road runs for pure power figures as opposed to rolling road runs for mapping etc?
Old Nov 26, 2008 | 10:53 AM
  #48
It's Czech Mate
Depends if the readings are taken with the fan running for a few mins first or not ?
Old Nov 26, 2008 | 10:56 AM
  #49
Garage19's Avatar
Garage19
True.
I would have thou DD would have issued some sort of method statement for performing a run that should clarify everythingn and lead to consistent practice between DD RR owners.
Old Nov 26, 2008 | 10:58 AM
  #50
dojj's Avatar
dojj
you'll be asking for TUV approval next
Old Nov 26, 2008 | 01:22 PM
  #51
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Good to see we have so many people on here excercising 'theory' and clearly knowing more than those that have actually used dyno's.
Using our method, Gary's Evo made within 5bhp at 640bhp on 2 runs that were WEEKS, if not MONTHS apart.
I bet there are only a handful of Dyno's in the country used by people that are more interested in giving what the operators feel are fair and honest (even if sometimes disappointing) figures, but a hundreds used by people that either can't accept a new way of doing things or who operate their dyno to make them look good.
Old Nov 26, 2008 | 01:38 PM
  #52
dojj's Avatar
dojj
but there in lies the heart of the problem
you cannot make the same resluts on 2 different days of the week as something will change, so you can only test it in the same way with the differences pointed out in temps etc of the probes and sensors that are still mounting in the same places for the original run
Old Nov 26, 2008 | 02:44 PM
  #53
Garage19's Avatar
Garage19
So what you are saying is that you have achieved 0.8 % variance between those TWO runs.
Can this be acheived with all your runs.
No one has said that they "know more than you" but no one with a DD RR has been able to come up with a definative answer.
Look at it this way, would you accept data as proof from 5 different labs that had done the same type of experiment but each made up their own test procedure?
Old Nov 26, 2008 | 03:05 PM
  #54
Christian and Beccy
#1 in Spelling Club
The temperature in the cell doesn't vary by enough to make a significant difference. If we were running the cars on a dyno outside, then I would expect to see more variation.
Old Nov 26, 2008 | 04:45 PM
  #55
Mike Gurney's Avatar
Mike Gurney
Air/Baro temperature correction is there to make sure the car makes the same power every time you run it (if you don't use it then it becomes almost impossible to see if you have actually made or lost power between different days)
the rules state the air temp probe should be at the air filter, measuring the temp of the air that the engine is breathing
however - if the Dyno cell / engine bay is not efficient then the temp you see may not be realistic - the dyno has to compensate for the temp that it measures
the beauty here is that if the operator has tried to fudge the graph - then its there as plain as day for all to see and can not be covered up ! plenty of dyno's hide this information
I'm not suggesting that this dyno operator has tried to interfere with this graph at all - what we can see however is that there was a higher intake temp than expected. It would be worth investigating why that was
Old Nov 26, 2008 | 06:22 PM
  #56
foreigneRS's Avatar
foreigneRS
Testing the future
it's also 'good to see' that some people actually using dynos seem to have little idea of the physics and engineering principles behind how they work
that would be some acheivement - a 100% or greater efficient intercooler
  #57
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Where do the manufactures say to place the IT probe?
Old Nov 26, 2008 | 06:33 PM
  #58
rapidcossie's Avatar
rapidcossie
Because if you dont, then you could run your car up on a very cold day and get a massively inflated figure that it wouldnt be able to adjust back down, likewise the opposite on a hot day.
And because if you build two identical engines and roller one on a hot day and one on a cold day they would get totally different figures.
How the hell is that useful for developing an engine?
Any engine from december would seem massively better than any engine you built in july!
Chip I undertstand why dynos do it but the DD rollers SOMETIMES seem to be so innacurate that its almost pointless.
Old Nov 26, 2008 | 06:44 PM
  #59
dojj's Avatar
dojj
i had one of them little widgets that mike r used to sell for measuring inlet temps and, on a cold day, i could see it going below what the outside tempsratures were so there may be something in it
Old Nov 26, 2008 | 07:58 PM
  #60
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Seems the saying "Dyno's only as good as it's operator" is very true
Old Nov 26, 2008 | 08:08 PM
  #61
Garage19's Avatar
Garage19
Hmmm i suppose pressure drop as it goes through the intlet track could cause a slight temp drop???
Old Nov 26, 2008 | 08:21 PM
  #62
foreigneRS's Avatar
foreigneRS
Testing the future
no, there can't be something in it one or both gauges were inaccurate or you were driving marty mcfly's delorean
Old Nov 26, 2008 | 08:29 PM
  #63
GaryEvo's Avatar
GaryEvo
he just did mate Mike Gurney is head of Dyno Dynamics in uk.
Old Nov 26, 2008 | 08:36 PM
  #64
Charlie Chalk
Unknown.
Oh, cheers lol
Old Nov 26, 2008 | 08:41 PM
  #65
dojj's Avatar
dojj
i don't think mikes gauges would under read by as much as 6 or 7 degrees mate
i'm sure you wuill find this isn't as uncommon as it may seem
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fiddy
21
Sep 29, 2015 06:10 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
