Track wheels........
Old Nov 17, 2004 | 12:41 PM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Default Track wheels........
I bought these of Ebay a few months ago......
They were advertised as fitted to a rally saph cossie and i thought they would be perfect for my S2 track car. Anyway, i tried to fit em and designed for studs and not bolts.
I thought the saph cossies were bolt fitterment and 3 doors were studs ???
Old Nov 17, 2004 | 12:50 PM
Phil's Avatar
Phil
Jeebus
Saphs have studs!!!
Old Nov 17, 2004 | 12:52 PM
Adam_BlackRS
Ex Ford Man
Ok, so is there any way i can get these alloys to fit ? longer bolts ?
I saw Tim's old bean tin with std saph alloys on, how did he fit them ?
Old Nov 17, 2004 | 12:56 PM
B19-TRB's Avatar
B19-TRB
u might b able to use longer bolts adam!
Old Nov 17, 2004 | 01:13 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Change the wheel bolts mate. You have to have special ones with collets or something. Or get a stud conversion.
Old Nov 17, 2004 | 01:25 PM
Adam_BlackRS
Ex Ford Man
http://www.graystonengineering.com/wheelnutmenu.htm
Is it safe to use longer bolts ?
Old Nov 17, 2004 | 02:05 PM
xr-stu's Avatar
xr-stu
rally design or speed shack can sort you out with a stud convewrsion. not just to get the wheels on but it makes life much easier.
or you can get bolts with collars on them to fit.
Old Nov 17, 2004 | 02:43 PM
cossy abuser's Avatar
cossy abuser
can get some long High Tensile bolts from a normal bolt supplier and get 4 tapered collars machines up, that will do the job, or sell the wheels to me
Old Nov 17, 2004 | 02:45 PM
SteveB's Avatar
SteveB
i had a stud conv on my old S1.... came from Rtec for about Ł30 from memory
Old Nov 17, 2004 | 03:20 PM
Adam_BlackRS
Ex Ford Man
what do you mean by that ?
Old Nov 17, 2004 | 04:57 PM
RichardPON's Avatar
RichardPON
Get a stud conversion!
Nothing worse than bolts if you want to change the wheels over trackside........
Old Nov 17, 2004 | 05:54 PM
Dave Henshall's Avatar
Dave Henshall
you need use tapered collars on nuts/bolts for use in alloy wheels. the bolt/nut face tightens up against the flat of the collar and NOT the alloy, so when u tighten and undo the wheels you are not gauging into the alloy each time. this not only can cause cracks in the alloy, but cuts through the paint/laquer and caused the ally to furr up and corrode.
ossie cossie
57
Nov 21, 2022 10:05 AM
gingeRS
17
Oct 2, 2015 09:42 AM
muzzman1
Sep 30, 2015 08:59 PM
SMILER258
Sep 28, 2015 09:04 AM
ossie cossie
Sep 21, 2015 05:07 PM
