So whats the next........
Thing your going to be doing to your car ??
Ive just run my new engine in, its now on the green injectors and running lovely!! But im looking under the bonnett thinking about the things i need , Complete set of new hoses, new intercooler to be fitted and a dam good clean up
* New wheels & tyres fitted
* Fit new wiper arms & blades modded by Dave aka TWINS
* Bit of paint work
* Dash trim replaced
* Bigger brakes alround
* Fit evo 5 rear spoiler
* Then start on engine and engine bay
Don't ask - I don't know
Driving it most likely. I've got a rear disc conversion that needs fitting but never got round to it this year so see what happens next year.
Either way nothing will happen now until April next year when she comes out from the winter hibernation.
umm well the shells off for blasting in the next couple of weeks,
then its ,
-off to the bodyshop for new panels , s1 kit, paint
-custom rear suspension setup
-brakes ,wheels , shocks , ancillarys
-fully rebuild the 2wd motor ive bought , low comp ,gt30 etc,
put it all together
then its ,
put it all together
mines coming into my workshop for some paint this winter, im thinking of some desert storm arch mods but i havent decided yet...
finish the engine thats now underway again.
in the new year it will be having diffs, and some interior work, and after using the t4 for some time, it may have a gt35 or the like fitted...
but mainly just use and abuse it
oh and the fast ford shoot will be done
got a wee list for mines too
new brake lines to be fitted
new bilstein suspension suspension to be fitted
recon shafts and diff to go in
then its the big build up
got new samcos etc too but bodywork first
engine rebuild and paint
bay smoothed and resparayed
fit the 330mm willwoods i had for 12 mnths
fit 044 pump and new cradle
powder coat rims
get t34 rebuilt and polished
remove single wiper
remove tints
sort sagging headlining in rear
a few more that i forgot/dont want to think about
powder coat rims
remove single wiper
remove tints
send my sump and inlet off to doug at garage 19,
then build it back up
then stu's for live map and als
then see how many times i can roll it(again) when i try to take duffis dip(car killing bit on knockhill) flat out
carbon 500 spoilers
carbon bonnet
carbon grill
carbon tailgate
half flocked dash
carpet out
paint the inside
more sections of the cage to add
new bucket seats
fit adjustable t,c,a's and comp struts
fit 355mm ap 6 pot's on the front
fit my ap 4 pot's to the rear
fit grey's
wrc head gasket
give it to joe to up the power
underside resto
erm thats all i can remember,
think i'm going to be busy
carbon bonnet
carbon grill
carbon tailgate
half flocked dash
carpet out
paint the inside
new bucket seats
fit grey's
wrc head gasket
underside resto
gonna sell the last of my frst parts and buy a subaru will only own another for if
A.its a second car that i use in the dry
B. it can sit in the garage all the time its not being used
finish off fitting my new discs,pads and rear caliper wich i have been waitng 3 weeks for !!!! then engine out .a build is due,and so is paint.that is if i keep it and dont go and blow my brains out and buy an escos.
get it over the unit
take the seat out
weld a few little holes up
fit 6 point harnesses
new manifold gasket
plumb the washers in
cut more metal out and drill more holes
paint the inside matt black
refit bucket seats
take the seat out
new manifold gasket
refit bucket seats
fit the teins and whiteline front and rear roll bars, rosejointed drop links, antilift kit, polybush the whole car, get geometry set up on its track wheels then test to see how far its out on the road wheels, maybe mark them up and re adjust
fit some decent bucket seats and harnesses then get hold of a block and start a rebuild ready for when this engine dies
