4x4 and EECIV inlet prices
How much do either of these go for?
4x4 spaced will suffice me really cos it only goin on a 380 bhp - 400bhp ish car. But I dont know what kind of money either make now. I gave £25 for my last 4x4 plenum
Rubber Rhino Crew
think the ST pleum costs 100-150 ish.....I was asfter one for mine but managed to do a swap on a complete st inlet,tb and iscv for my 4x4 one plus a loom..
I have been after one for the right money for a long time, probably 6 months looking....not many come available.
The 4x4 should be good for thepower you want.
Dan
Dan
Rubber Rhino Crew
that for just the cover or complete with throttle body steve?
Reason being I swapped a full 4x4 inlet and a standard loom for a st inlet complete....reckon I got a deal there!!!!!
Dan
Dan
Just done a quick search and found this on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=016
It looks as it has had the act sensor fitted in the norm position and the vac take offs are at the front.
Steve
Steve
Rubber Rhino Crew
std 4x4s are meant to be good for around the 450 mark.
The ST escos covers dont have the central bit where the act and vac pipes come off of, they have them on the very ends of the plenum. Also the throttle body flange measures ~70mm as apposed to LT which is ~60mm. They are slightly deeper too from what I can see.
cheers
Dan
cheers
Dan
Rubber Rhino Crew
does anyone know how much the throttle bodies go for? I have a 70mm ST escos throttle body but want to stay L8 so if its not worth a deal I'll have it converted to run L8 TPS.
Dan
Dan
You may have measured it, but you have measured incorrectly.
You are measuring external sizes, and whats the point of doing that???
I could turn up a TB with an external size of 63mm (common hose size) but only have a 30mm diameter bore through it.
At the point where the throttle plate is and at its smallest INTERNAL diameter saph ones are 55mm and the ST ones 60mm. I have a ST one on my car in my workshop.
Rubber Rhino Crew
I would rather have a proven ford designed part over a fabricated swedish tbh, at least you know you will be getting even airflow to all cylinders then, SOME (not implying garage 19 inlets are good/bad/indifferent) can restrict airflow to No4.
while this is here are the covers are different BUT are the trumpet parts the same LT + ST as i am thinking of getting mine ported!?
Thats wrong. No swedish type plenum restricts flow to number 4, in fact quite the opposite.
Rubber Rhino Crew
Like I said I'm not knocking your inlets, never seen one to comment on so would be unfair of me to do so....I'm just having my opinion that for the same kind of money I can have a ford researched and developed inlet capable of more power than I require.
You cant say any swedish style is good, I've seen home made jobbies on ebay that are like cornetto cones, you can't tell me theyre getting even flow to all 4 cyl.
Dan
If an inlet manifold is a restriction at when flowing 450 bhp worth of air through it will stiil be a restriction at 350 bhp. The negative effect will be less and proportional but it will still have an effect. I have done back to back tests with a stock plenum that show airflow is considerably increased with my plenum. Enough to make a good difference even on a T34 engine.
It is the tapper in the manifold that is the critical part of the design which prevents un equal flow.
truffleshuffle
10-09-2015 09:35 PM
