Coil pack location
Old 14-11-2008 | 06:55 AM
NEIL A's Avatar
NEIL A
Default Coil pack location
Im going to be switching to coilpack soon to get rid of my high boost missfire, was thinking of places to mount the coilpack out of sight.
So question
1. Do they need to be sheltered from water as was thinking next to the battery under the slam pannel.
2. I got a set of leas from Euan along with other parts but he had his coilpack mounted in the original map sensor position due to his ecu having one inbuilt, would it cause problems mounting it close to the map sensor or is there a set distance to have them apart.
Old 14-11-2008 | 07:11 AM
Not a good idea to mount near any sensor, due to HT voltage and possible interference.
I have seen one mounted behind the firerwall panel, but I have mine in the std coil place, even the tps can pick up interference and some peoples ht leads are right next to it.
Old 14-11-2008 | 10:12 AM
NEIL A's Avatar
NEIL A
Thanks Tabetha thought interference might be a problem with the map sensor.
So is there any problem with water ingress if i mount it behind the firewall panel as i may do a swedish style cam cover at some point to cleaner for running the leads to there.
Old 14-11-2008 | 04:51 PM
KSA-Cossie's Avatar
KSA-Cossie
What about on the srut brace neil ?
Old 15-11-2008 | 05:58 AM
NEIL A's Avatar
NEIL A
Did think of that Kev but my engine bay is fairly tight at the passengers side with the breather and remote iscv housing.
Old 15-11-2008 | 07:37 AM
Shouldn't be a problem with water there as all leads etc are sealed, but could always put in a plastic bag to be safe ?
I'm going to mount mine under the inlet eventually, if there is room, haven't had a look yet.
Old 15-11-2008 | 12:44 PM
KSA-Cossie's Avatar
KSA-Cossie
This might help neil.
https://passionford.com/forum/showth...ight=coilpacks
Old 15-11-2008 | 12:47 PM
Tev's Avatar
Tev
ive mounted mine behind the bulkhead, near the heater motor, under the scuttle pannel,
was kinda worryed bout this as it aint exactly a dry place, but have done over 2000 mile without a single problem
will post picks up if i can find them
Old 15-11-2008 | 03:29 PM
NEIL A's Avatar
NEIL A
If you have a pic that would be grate Tev.
Think i may mount it under the cover there aswell, think it may have been Damo that use to be on here fitted his there aswell.
Old 15-11-2008 | 03:35 PM
ECU Monitor Enthusiast
Its the best place for it to remove interference issues EXCEPT for the possibility of potential water problems !!!
I would advise a cover over it if it was mine..
Old 15-11-2008 | 06:15 PM
Tev's Avatar
Tev
just had a look and cant find ther photos i took
will b in the garage tomorrow so i wil take a couple of photos for you fella
Old 15-11-2008 | 06:49 PM
col cos1's Avatar
col cos1
im going to mount mine on the strut brace with mine being a box section brace
Old 15-11-2008 | 10:19 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Is there any reason why you cant fit it where the original coil was?? Just seems obvious place to me.
Old 15-11-2008 | 10:47 PM
SS1's Avatar
SS1
in front of the header tank
Old 15-11-2008 | 10:51 PM
Psycho Warren
Carbon Crazy
hows it held there??? you got a mount underneath???
Old 15-11-2008 | 11:47 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Got mine in the standard coil location.
just cut 4 equal length pieces of alloy tubing and drilled some holes in the inner wing and just held it all together with nuts and bolts! Job done!
Old 16-11-2008 | 01:07 AM
xr4x4rs's Avatar
xr4x4rs
can see where mine use to be on the strutbrace
Old 16-11-2008 | 01:10 AM
Psycho Warren
Carbon Crazy
My standard coil has some metal frame to hold it in. Im thinking i will try and bastardise that to fit the new coil pack
Old 16-11-2008 | 06:14 AM
NEIL A's Avatar
NEIL A
Main reason is i think i will go for a swedish style cam cover in the future so easyer lead run if the coil is at the back of the bay.
Old 16-11-2008 | 07:54 AM
Tev's Avatar
Tev
thats why i lokated mine by the heater motor to make it super clean no leads to b seen
i originally located my coil pack infront of my header tank on the wing
Old 16-11-2008 | 08:24 AM
I just did mine a bit quickly and used 2 x 5mm bolts, through the inner wing, using one original hole but had to drill one more, there are loads of holes there, just nut/washer on underside of inner wing, but will be getting a zetec type coil mount and putting on upright part of inner wing so it sits nice, as I have the blingy yellow ended accel coil!!
Old 16-11-2008 | 08:32 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
AJC
01-10-2015 06:47 PM
Steve Escos
01-10-2015 06:57 AM
Quick Reply: Coil pack location
