Help with engine mounts on my mk3 rs16i
Old 12-11-2008, 08:07 AM
D200RST
D200RST's Avatar
Default Help with engine mounts on my mk3 rs16i
I did a search first, but no luck, so..........
I have a zetec turbo engine that is currently in a mk4 escort. I will be fitting it into my rs1600i.
I will be picking up a S1 box in a few days, will that bolt onto the zetec? What flywheel and clutch is best?
(The RS1600i currently has the original engine and box)
What mounts will i need to fit it all in?
Thanks for any help here guys!
Old 12-11-2008, 10:12 AM
rst in breaking
rst in breaking's Avatar
standard mk3 mounts will bolt it up, if you had it bolted to a gearbox in a mk4 it will fit the mk3 but you will need to mod the mk3 mount as they're diff from the mk4 sadly
Old 12-11-2008, 06:06 PM
D200RST
D200RST's Avatar
Cheers mate, do you know what i need to do to modify the mount to fit? So i can get things ready for when i do it.
Old 12-11-2008, 06:25 PM
dangerousbrian
dangerousbrian's Avatar
s1 box will fit onto zetec engine and will use the same munt from your rsi...mk3 engine mount will need a bolt hole taking off and welding on in a different position (if that makes sense?). me and my mate did this conversion and used the flywheel of the zetec..clutch is whatever u need in terms of power etc..iirc we used a s2 clutch
Old 12-11-2008, 06:44 PM
rst in breaking
you need to weld a plate on the corner of the cvh mount, if you bolt the mk3 mount to the zetec engine you will see you can only get 2 bolts in and you need atleast 3 so welding a corner to it and drilling a new hole then notch mount around oil pump
Old 12-11-2008, 06:53 PM
curlie467
curlie467's Avatar
http://www.escortupgrades.co.uk/Esco...s%20Index.html
Have a look on here. Click on engine and he writes about modding a mount to suit.
If you need one of the engine mounts he is talking about (rubber rare mount)
then i have a new one available.
Old 12-11-2008, 07:15 PM
rst in breaking
i have a couple of new ones too
Old 13-11-2008, 04:03 PM
D200RST
D200RST's Avatar
Cheers fellas! PM sent RST
SmudgerByName
52
28-07-2016 06:14 PM
Carlbacciochi
24
30-06-2016 04:31 PM
track.focus'd
12-08-2015 05:53 PM
st220kyle
Ford Mondeo Including ST
06-08-2015 09:17 PM
lockie
31-07-2015 10:03 PM
Quick Reply: Help with engine mounts on my mk3 rs16i
