Siemens injector help
Old 09-11-2008, 02:21 PM
BRAMMER
BRAMMER's Avatar
Default Siemens injector help
I'm looking to change my injectors from Bosch to Siemens and would like to know which ones from the company linked below are the ones i want?
High or low Impedance??
What lb is needed for a T34 .63 ??
http://www.fiveomotorsport.com/Injector_SetsMODS.asp
Any help would be great
Old 09-11-2008, 02:25 PM
Jay,
Sponsor
Jay,'s Avatar
either the 3102's or the 3105's mate
Old 09-11-2008, 02:35 PM
cossiegreg1
cossiegreg1's Avatar
Old 09-11-2008, 03:12 PM
BRAMMER
BRAMMER's Avatar
Where the best place in the UK to source these from as the price from the states is around £155 but ones you've been stung with import tax and VAT and admin costs they could work out just as much.
Old 09-11-2008, 03:18 PM
glancy2081
glancy2081's Avatar
a bought a set of ebay from matt lewis for 150 a few months back
Old 09-11-2008, 03:19 PM
Jay,
Sponsor
Jay,'s Avatar
matt lewis is about the cheapest iirc
Old 09-11-2008, 03:55 PM
BRAMMER
BRAMMER's Avatar
Cheers i'll give matt a call
Old 09-11-2008, 04:09 PM
LHD220Turbo
LHD220Turbo's Avatar
2.8ohms, low imp
the dollar is quite strong at the moment; so its not such a good deal - when i bought mine it was $2 for £1 so i got them for a bargain
although to be fair; i didnt have to pay any import duty.....that's just pot luck tho
Old 09-11-2008, 04:11 PM
LHD220Turbo
i'm sure you already know this but just in case....you know you'll need to change your chip to run these Siemens dont you?
Old 09-11-2008, 04:45 PM
BRAMMER
BRAMMER's Avatar
Yes mate, i've still got decide which way i'm going after removing L1
Old 09-11-2008, 04:48 PM
LHD220Turbo
l8, with ALS & closed loop....... there i've decided for you
Old 09-11-2008, 04:49 PM
JTECH James
Passion for Fords!
JTECH James's Avatar
make sure your chosen tuner has files for the injectors you choose, especially if you want it done off the shelf.
Old 09-11-2008, 08:14 PM
Jay,
Sponsor
Jay,'s Avatar
Thats why i gave those part numbers as there most popular.
Old 13-11-2008, 09:51 AM
BRAMMER
BRAMMER's Avatar
Just need a little more help before i purchase a set,
The 83lbs/hr - 865cc/min - would it worth running these as an over engineered option so that in the future they would be acceptable for further modifaction's or would the 55lbs/hr - 575cc/min cope??? what are these maxed out at???
Chris.
Old 13-11-2008, 10:07 AM
Jay,
Sponsor
Jay,'s Avatar
id say get the 83lb ones then you have room for bigger turbo ect later
Old 13-11-2008, 10:13 AM
LHD220Turbo
Chris.
i understand the 83lb are the same price as the 55lb & 72lb - so i would go for the 83lb ones and "future proof" yourself so to speak
the 55lb should be good for around 420-450 ish
Old 13-11-2008, 10:15 AM
BRAMMER
BRAMMER's Avatar
Cheers for the advice lads
mk3ste
17-10-2021 10:09 AM
Mark_
14
16-01-2016 05:27 PM
01-11-2015 06:53 PM
timsrs
22
24-09-2015 08:14 PM
cos elle
16-09-2015 06:37 PM
Quick Reply: Siemens injector help
