bd10 cams make a differance???
Old Nov 8, 2008 | 09:20 AM
B13 JUS's Avatar
B13 JUS
Default bd10 cams make a differance???
i have a set of bd10 cams. would they make a difference to my car if i put them in??
i running light blue injectors tt t34/55.
Old Nov 8, 2008 | 09:50 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Yep!!
Total ruin what you have, aint called the 'lag' cams for nowt.
Old Nov 8, 2008 | 09:53 AM
B13 JUS's Avatar
B13 JUS
Originally Posted by MadRod
Yep!!
ok cheers. i'll just sell them. lol
what are they worth?? think they are genuine cams as they don't have the ford stamp on them, if you know what i mean.
Old Nov 8, 2008 | 09:58 AM
polly_x's Avatar
polly_x
Before you just sell them I dont think youve found out very much?
Rod has said they may cause more lag but for what benefit elsewhere? Maybe they would give you some more power at mid and top end???
What is it you are after?
I dont actually know myself but think youve only heard one small bit of info.
Old Nov 8, 2008 | 10:05 AM
B13 JUS's Avatar
B13 JUS
i thought rod would know best???
is that what the bd10 cams do... mid and top end?
i've never heard many people using them thats all mate.
Old Nov 8, 2008 | 10:12 AM
polly_x's Avatar
polly_x
There is about a million threads on here talking about exactly what you want to know already. Maybe have a search around and see what others think. Personally Ive never used them, and I doubt Rod has either as he is probably on some secret ones......actually maybe thats the secret...They are just BD10's
Old Nov 8, 2008 | 10:14 AM
cossie604's Avatar
cossie604
I always assumed the secret spec engine parts were reserved only for people with very deep pockets and no clue
Old Nov 8, 2008 | 10:15 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
The BD10 cam profile was designed back in the 80's by cosworth as a performance cam for the yb engine on stock pistons and compression and a t3 .48 turbo.They are one of only a couple of cams you can fit to a stock yb.
My advice on your engine is to fit the inlet only at 118 degrees ,leave the stock exhaust cam and set that at 108,and get it mapped to suit
Old Nov 8, 2008 | 10:24 AM
rsnissan's Avatar
rsnissan
exactly what I had, didnt think it was a problem but then again never drove it with stock cams.
I think it depends on the car (4x4 or 2wd) and the situation you would most likely to use the car for. i.e you prob want response lower down for B road and wouldnt not be that fussed about top end where as a RWD motorway blast would be the opposite
Old Nov 8, 2008 | 10:35 AM
graeme's Avatar
graeme
What about the BD10R?. Tony is it any better than the BD10 and if so where in the power band is it better.
Thanks
Graeme
Old Nov 8, 2008 | 05:53 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
id also like more info on this as someone advised me on bd10s ,
what would be a better option tony - 12s ?
Old Nov 8, 2008 | 06:22 PM
jacko's Avatar
jacko
can go alot bigger mine had 14s in but need pistons to match em
Jman-pat
Ford Focus Diesel
Nov 8, 2015 11:06 AM
Sheepdisease
Aug 30, 2015 09:11 PM
gingerturbo
Aug 18, 2015 07:58 PM
kyle_st200
Ford Focus (All Models)
Aug 7, 2015 06:06 PM
