Noooooo! Not now
i dont believe it . here i am all ready and happy i have a new job.(great day)
i got in the car to go see a pal and only a little light boost i noticed there was something wrong
alot of white smoke and my car now sounds lik a scooby![Wall](https://passionford.com/forum/images/smilies/wall.gif)
i start pullin leads out a no3 makes know difference unpluged.... it still was boostin and smoke died down on boost but at a stand still a little light revs and it is porin out the back
this could n ot have happened at a worst time.
fookin sick!!!!
fookin sick!!!!
have not nothiced it look okay BUT just before it went i had got out the car (still runnin as was cooling down) and i heard a hisin noise . i lifted the bonnet and it was coming from the water tank. i felt the tank and it was not hot or a boilin noise it sounded lik pressure. if you now what i mean.?
I know mines not a Turbo, but when my CVH sounded like a Scooby it was the Big end Bearing in cylinder 1, looks like there was oil starvation co when I had the rods out, it was the only oil way that I had to clean.
how long should it take to build pressure? i dont have any tools here but i will take plugs out tomorrow and do a compression test. i am prayin its just a head gasket not piston or valves
If it was between two cylinders, would that cause the Scooby sound?
Baby Cheesus
when my old 200sx sounded like a scooby it turned out it was because it had burnt a hole in an exhaust valve.
i still drove the peice of shit to work for 3 months on 3 cylinders tho while i sourced another engine, used less fuel too, but was piss slow![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
no smoke tho lol, that was cos the turbo was fucked
big thanks .... took the car this mornin to dmc and he done a block test and it is head gasket which i am relieved about. spoke to a mate and its getting sorted tuesday!
thanks
Check your thermostat works ok before trusting a gauge. had a R5 that never moved the needle, sat in traffic one day and blew the head gasket, had to have the head skimed, but it was to late, just kept poping head gaskets like no tomorrow.
