Roast dinner HELP
Old Nov 2, 2008 | 12:44 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default Roast dinner HELP
i have a big chicken, a swede, carrots, and potatoes....
now what?
Old Nov 2, 2008 | 12:46 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
a suede? whats that then? jacket or trousers?
Diseasel's Avatar
Diseasel
light the oven put the chicken and cook for a few hours
S1rst's Avatar
S1rst
Leave em there and go to KFC!
Old Nov 2, 2008 | 12:47 PM
fuzzy's Avatar
fuzzy
Originally Posted by JTECHSAFF
i have a big chicken, a suede, carrots, and potatoes....
now what?
now you phone your bird and get her to come around and cook it for you
Old Nov 2, 2008 | 12:49 PM
JTECH James
Passion for Fords!
shes here asking me
Old Nov 2, 2008 | 12:50 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
lil mark's Avatar
lil mark
yorkshire puddings
Old Nov 2, 2008 | 12:53 PM
JTECH James
Passion for Fords!
Originally Posted by Statey
swede
like the plenum
Old Nov 2, 2008 | 12:54 PM
Dearo's Avatar
Dearo
Par boil Pots and roast in Goose fat ! Yum Yum
fuzzy's Avatar
fuzzy
shes here asking me
phone your mum, they know about that old school cooking stuff.
Old Nov 2, 2008 | 12:56 PM
JTECH James
Passion for Fords!
plan!
Old Nov 2, 2008 | 12:57 PM
kosman's Avatar
kosman
sideways all the way!
mash the swede and carrots together,drown in gravy mop up with bread
Old Nov 2, 2008 | 12:59 PM
coswurv's Avatar
coswurv
Lol, can build a ££££k yb lump etc but cant cook a chicken and boil some veg
Diseasel's Avatar
Diseasel
Learn from mistake of buying the raw ingredients and then next week to your local carvery the saviours of the roast dinner
Old Nov 2, 2008 | 01:00 PM
JTECH James
Passion for Fords!
true
Old Nov 2, 2008 | 01:01 PM
tommy6206's Avatar
tommy6206
rinse chicken then put some butter under the skin,place in roasting dish.Peel spuds carrots and swede put spuds in roasting dish with chicken and place in oven @180. Dice swede and carrots place in pot and simmer for 20 mins or so until swede is soft then drain- mash with butter drain carrots and add a knob of butter. Chicken will take about 1.5 -2 hours to cook so adjust veg times to match.. don't for get the stuffing..
ps sprinkle a little salt on chicken for crispy skin.
Old Nov 2, 2008 | 01:02 PM
JTECH James
Passion for Fords!
ohh a pro
Old Nov 2, 2008 | 01:03 PM
tommy6206's Avatar
tommy6206
And save the veg water to make gravy.
fuzzy's Avatar
fuzzy
everyone has their own strengths and weaknesses, can gordon ramsay change a head gasket?
Old Nov 2, 2008 | 01:05 PM
Rs(555)'s Avatar
Rs(555)
cant cook a chicken and vegfook me mate what food do you live on ? beans on toast just have a go see what happensgood luck pal..
Old Nov 2, 2008 | 01:08 PM
spookie's Avatar
spookie
gravy
Old Nov 2, 2008 | 01:12 PM
RichardPON's Avatar
RichardPON
I wrote this on here ages ago - should be fairly foolproof:
Roast Chicken.
Remove all packaging, and clean out all the guts from inside. Open up the legs, and place a half lemon inside (whoo-hoo etc). Place the chicken in a roasting tin.
Smear the chicken with butter. Slice a couple of small cloves of garlic, and place a slice in between each wing and leg. Drizzle the whole chicken in olive oil. Add 150ml of water to the roasting tin. Liberally season - i.e. add lots of salt and pepper.
Cooking method. Place the prepared chicken in a preheated oven at 190c. The secret to getting that moist chicken is to baste the chicken at least every 20 mins. It will take somewhere over 1 hr 15 depending on the size of the chicken The way to tell that it is done is that when you tip it, the juices will run clear.
Tip the juice from the chicken in the roasting pan and then remove the chicken, place it on a chopping board and cover it completely with tin foil. Allow it to sit for 10-15 mins. It will not go cold, and all the juices will soak back in.
Gravy
Boil a kettle, and add a relevant quantity of boiled water to the roasting tin. Pour the contents of the roasting tin into a separator jug, and leave to settle. Pour the separated gravy into a saucepan, and place on the boil. Do this whilst the chicken is sitting, and whilst vegetables are on. Bring the gravy to the boil, and then drop to a simmer. Take a mug, and add a teaspoon of cornflour, and enough cold water to take the mug to about 1/8th full. Stir thoroughly, and then add some of the boiling gravy to this mug. Stir thoroughly, and pour back into the boiling saucepan. This will thicken the gravy slightly. Add a splash of red wine. Switch off. Don't worry about the skin that may form. It's only fat based.
Don't throw away the fat in the separator jug - put in a mug, place in the fridge for next weeks roasts....
Roast pots.
Maris Piper or King Edwards. Peel and cut into the correct size. Place them into a pan with cold water covering them and a liberal helping of salt. The salt is important as it keeps the composition.
You can do this as soon as the chicken goes in, as it takes the pressure off. As described above, boil to the point that you place a knife into one, and it gently slides off the knife. Drain the potatoes and leave them to sit for a while. Leaving them to go cold is a form of blanching, and will ensure they have that fluffy centre.
Work the timing backwards. They will take about 45 mins, so estimate when you'll have to put them in the oven. It doesn't matter if you're early as when the chicken is removed, you can leave them in the oven and they will stay hot.
About 5 mins before the pots are due to go in, place a roasting dish for the pots in the oven with a large lump of goose fat in (available from any supermarket). Give it 5 mins till the goose fat is melted and spitting, then remove the dish, add the potatoes. Season throughly (lots of salt and pepper). Place in the oven with the chicken (about 45 mins into the chicken's cooking time depending on size). You'll want to turn them at least once during their cooking time. Keep an eye on them, and you'll see when they're ready. They'll have that golden crispy look and will taste amazing.
That lot should help. Remember if you make yorkshires that you shouldn't really open the oven, or they may not rise properly. Don't buy ready made. It's flour, milk and a little butter for god's sake! Veggies. Don't overcook them. The best way to see when they're done is to taste them. Cook carrots in butter and sugar. Caramelises to give a sweet flavour.
Old Nov 2, 2008 | 01:15 PM
Munch's Avatar
Munch
Mr. Sparkle!
shes here asking me
So Doug is the bitch in your realationship then James
Old Nov 2, 2008 | 01:40 PM
spookie's Avatar
spookie
Horseradish sauce
Old Nov 2, 2008 | 01:48 PM
Miller 3's Avatar
Miller 3
Just like Radders is yours
Ps i can make a mean roast dinner ... Only do it at Christmas tho
Old Nov 2, 2008 | 02:04 PM
DanRSturbo's Avatar
DanRSturbo
My Mrs is top drawer at doing roasts and is in the proceeds of doing one now, along with some chockolate corn flake cakes
Old Nov 2, 2008 | 02:08 PM
CliffRS4's Avatar
CliffRS4
Have you heard of looking up recipies on google
Chef by trade in the army here. One that can cook
Cookings easy when you know how.
A whole roast chicken should take 1 hr 20 mins.
P.S. Don't wash your chicken as you will no doubt splash water off of the raw chicken everywhere.
Sure fire way to get food poisoning.
Old Nov 2, 2008 | 02:10 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
We are having roast pork(crackling.......yummy) with trifle for desert.....food dont get much better than this.
Steve
Old Nov 2, 2008 | 02:39 PM
arch's Avatar
arch
I'm just in the middle of making our Sunday meal, beef mmmmmmmmmmm.
Carrots in butter & suger are delicious, but today I is mainly roasting my carrots. I par boil em first then chuck em in with the beef. Also wifey does not like veg, so pan frying some mushrooms with butter and black pepper to keep her sweet. Must ocnfess though, frozen Yorkies as I only need to make 5
Forgot to add, made some cookies for pudding with teddy grays ice cream.
Old Nov 2, 2008 | 03:13 PM
JTECH James
Passion for Fords!
im giving it a go....fingers crossed its fit for human consumption
Old Nov 2, 2008 | 09:52 PM
JTECH James
Passion for Fords!
It was bloody handsome!! Thanks for the advice
Old Nov 2, 2008 | 11:35 PM
spookie's Avatar
spookie
mint sauce
Old Nov 2, 2008 | 11:57 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I do love a roast chicken! Got it tomorrow
No fucking chance!!
alexbarnes95
11
Sep 15, 2015 10:26 AM
D1on
Was It You?
Aug 8, 2015 01:36 PM
matts1
Jun 9, 2005 10:55 AM
