Stripped head bolt thread out block, How do i repair??
When torqueing the head bolts it pulled the thread out the block, the bolt is fine.
What can be done to repair this??
Can they HeliCoil this type of thread, given the pressures they are under??
Or should i open the thread up from a M10 to a M12 and use larger bolts??
Thanks for any help.
Matt.
Matt.
Originally Posted by Steve@SCC
If there was enough room i'd probably go with a larger bolt if not helicoil it
I've checked and there is loads of room. Its a 2.0ltr zetec block.
The only other thing i would have to do is open the holes through the head from 11mm to about 12.5mm
borboyous
22-08-2015 11:17 AM
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
track.focus'd
12-08-2015 05:53 PM
Jack and the Beanstalk
09-08-2015 07:03 PM
