fiat brembos
fiat brembos
hi all just went out the breakers near me and there is a fiat 20v turbo coup with some phat brembos brakes on the front is there anyway i can use em on my s2
has anyone ever used them? they said i could have for £80 bucks
ELASTIC BAND
you can make mounts up to bolt them on,
but when i looked at them for my sierra , the issue was the caliper being 58mm from the disk, so would catch the alloy with the ford offset
Dont matter tho dose it, they look cool, I would rather have a car that looks cool that a car that looks shit but goes like stink!
I want some big breaks on my 306
Col cos1 fitted some to his 3dr.
He got zoo to make up the brackets
https://passionford.com/forum/restorations-rebuilds-and-projects/264207-my-3-door-story.html
the brembo's are standard on some Fiat 20V Turbo's - they will fit but you'll need to make a mounting bracket or some kind of spacer to make them perfectly aligned i'd imagine.
but yes, worth £80 all day long even if you end up selling them on again.
They come std on every 20v turbo iirc
Thats looking good Dan
Evo Brembos fit behind a 17 inch wheel, I've 345mm disks behind 17inch MO's and there's still a few mm's left.
If your zooming in on this pic you can see the little clearance thats left
i had alfa brembos on my escort which i made up brackets for before but should have got bells/rotars to change the disc offset as the st170 discs put the calpiers too far out
I would imagine its possible, but when i picked up my AP's for my old saff, we were looking at coupe brembos, and i remember shaun saying something about the piston sizes, and how they can be different, depending on where the caliper is, leading edge or trailing edge. As the coupe brembos (and FRS) are leading edge and saff brakes are trailing edge its worth speaking to an expert about it.
1 Post
Another option to look at for people wanting Brembos is Porsche 993 red ones, or the Boxster S ones which are the same but black.
I had them on my Audi S2 with 323mm Audi S8 discs
jason_nike
18-08-2019 10:53 AM
OrionRST200bhp
29-09-2015 08:30 PM
NC53
13-09-2015 03:05 PM
