Old Oct 29, 2008 | 03:46 PM
paceo's Avatar
paceo
Question .
Old Oct 29, 2008 | 03:52 PM
rsnissan's Avatar
rsnissan
you should be able to adjust the rod if you slacken teh nut off and lock it back in place when done
Old Oct 29, 2008 | 03:54 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Rod screws in to adjust it before you fit it - rule of thumb is to set it with half a hole preload - i.e. set it so that you dont place it over, set it so that you need to pull it over by half a hole if that makes sense!
paceo's Avatar
paceo
the cover that screws onto the actuator rod is screwed on as far as it can go
Old Oct 29, 2008 | 03:55 PM
Lee_R21Turbo
Well unscrew it all the way then & chop the rod down!
Old Oct 29, 2008 | 03:57 PM
paceo's Avatar
paceo
yes that was like that with my old actuator you had to pull the rod about half a hole to fit onto the wastegate arm, with this new actuator you need to pull the wastegate arm onto the rod.
rsnissan's Avatar
rsnissan
use some man skills as above
Old Oct 29, 2008 | 04:06 PM
paceo's Avatar
paceo
just started raining
i will cut about 4mm off the rod tomorrow so it will keep the wastegate shut!
Old Oct 29, 2008 | 07:39 PM
paceo's Avatar
paceo
well cut about 4mm off as you lot advised on and it keeps the wastegate arm closed she will boost to around 6psi.
problem is its going in to be set up next week and upped to 8psi (standard boost) but theres only a few turns of thread left before it runs out on the actuator it has STD stamped on it if that helps.
Old Oct 29, 2008 | 08:41 PM
The Youth.'s Avatar
The Youth.
Originally Posted by paceo
was thinking of making a metal plate up about 5mm thick and stick it between the actuator and bracket, so i will have more thread left on the rod. what are your thoughts?
that would work
steve
Old Oct 29, 2008 | 08:43 PM
paceo's Avatar
paceo
Originally Posted by the youth
that would work
steve
thanks mate, just means i will have some extra thread on the rod so the boost can be turned up to 8psi when i get it set up
Old Oct 29, 2008 | 09:27 PM
Jim Galbally's Avatar
Jim Galbally
wait wait wait wait wait!
std actuator with correct preload will hit about 3-4psi
-31 actuator with correct preload will hit about 7 or 8
-34 about 14
(nb not accurate figures)
the cars acheive higher boost via a boost control device IE an "amal valve/bleed valve"
set the actuator to the CORRECT preload and adjust your boost with your bleed valve.
don't overtension your actuator youll just damage it
Old Oct 30, 2008 | 04:13 PM
paceo's Avatar
paceo
-34 about 14
thanks jim, well ive wound it down to that length just to keep the wastegate arm closed as it should be, any further wound out and it keeps the wastegate arm open a tiny bit. have only driven the car around the corner for about 0.3 miles just to see what boost it held at which was 6psi.
Old Oct 30, 2008 | 04:19 PM
Mint FRST's Avatar
Mint FRST
-34 about 14
Especially not for a T2 actuator.....
