General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Ive read all the Ad's and Hype in all the 'Mags' ...But which is considered to be the best Air Filter on the Market..Not for looks, but for the BEST air filtering, performance and engine safety....thanks All... Wilmot (Liege-Belgium)...
are you talking about a cone filter or are you talking about the panel filter that goes into the airbox
i believe some tests have shown you get more power from retaining the airbox. The cone filters seem to suffer from heat soak
Cone filter for the noise if anything once the car is motoring the heat soak issue subsides a little bit, you can always shield it off to help prevent heat soak
Its only the Filtering qualities im looking for....not looks, but has to be a 'Cone' system...If i need to buy a heat shield, i will, but back to the same old question... which is the best......NOT best looking, but best for the job inteneded..........By the way I have a K&N 57i system and to me the filter seems to be coarse, allowing quite large particles through.....cant be good for the engine..............or is it???????????????????????
As long as they're cleaned and oiled as per the instructions in the box, the oil will trap the larger particles.
I've got a Group A K&N on my Focus RS, have a few more horses over the smaller Focus RS Gen2 K&N, plus it looks and sounds better. But on a Cossie, the story is different I guess....I'll go with the last reply
