what should the oil psi presure gauge read?
mines 25psi ish , then 45 ish when drivin, is that good or bad and does anything else affect it (breather systems, high oil pressure pumps)
when mines is cold its about 60 ish but when it warms up it gets the readings above, so it seems to be down to temp of the oil then?
deffo temp of oil affects it, if i start mine from cold the oil pressure will rocket straight up to 60 under normal running temps on idle i think mine sits around 40 ish
matt
matt
excellent mate, at least i know mines ok now, was a bit worried as i never had a oil pressure gauge before and seen it goin up and down and thought is that normal
Adam Graham
06-09-2015 06:04 AM
