4x4 pistons for 2wd
4x4 pistons for 2wd
im sure this has been asked but just want to be sure .
been offered some 4x4 cossie pistons for my 2wd sapph cos ( 205 block)
there 1mm oversize i know i will have to machine to suit but just wanted to know if there is anything else i should be aware of ?
bloke said something about comp being 7:2:1 ?
be gentle im new to the cossie scene lol
any help much appreciated
Tony
Tony
std 4x4 pistons in a 2wd engine will lower the cr to about 7.8:1 from 8:1 so i would have thought that these would end up being closer to 7:1 in your 2wd engine than 7.2:1.are you going for big power?as these will be low comp of the type usually used in 500bhp engines of old.
cheers for the replys guys they wouldnt be going in a massive powerd engine will only be running 350 ish.
so they will be ok if fitted correctly ?
yes its on std bore but needs a rebore . its a 205 block i plan to run these in the 205 1mm over size. then while thats in the car (as we all know we want more power) so while thats running i will be building up a 200block ready to upgrade for 450+.
COSTINA- they have got valve cut outs already
truffleshuffle
10-09-2015 09:35 PM
Adam Graham
06-09-2015 06:04 AM
