YB cylinder head experts - can this be repaired
Testing the future
hard to tell from a photo i know, but is there any chance that this can be repaired (for use at stg1 only) and at what cost?
thanks for any advice
does look bad, but I know amac engineering who built my engine are experts in rebuilding alloy heads, I have seen some of there work when damage has been similar to this and you would never know! Cost may be a factor tho, cossie heads are still around at the mo just., and im sure the one I saw with damage like this was a bda head or something equelly valuable where repair was the cheapest option.
steve
steve
A bloke called Ken from Teeside has had similar recently where all 4 valves have had the heads snapped off and mashed into the piston and head and he is going to get it repaired.
It happened on his 6R4 at over 9k rpm
SPAM lol
New head time.
I believe that one may just manage to (once its ported and polished again) become an excellent doorstop
DMC
New head time.
DMC
Bodybuilding
Location: Cannot be identified by the information given.
Ive an old head here with similar damage, a lot of the ali mush you see in the bowl is actually from the piston, once thats removed the head is quite resiliant to damage.
You have nothing to lose by clearing that away and look at the actual damage, but even if it does clean up, the ali around the valve seats may by compromised as discussed elsewhere, and is it worth the risk of re-use only for it to drop a valve seat.
Biggest problem will be finding a decent used head as most out there also need money spending on them and usually only have one more go left in them before they are scrap as well
Norris Motorsport
Yes I can repair that for you, it will require full welding of the chamber, 4 new seats fitted, chamber remachined back to shape, new valve guides, seats re-cut and head re-machined. Cost from myself will be around £300, so given the thin state of the head, I'd advise a good 2nd hand one.
Get on That!
you can tell if you look at how much flat surface there is where the Water Temp sensor is located (the bracket has been removed when the head has been skimmed previously) as in top right of this picture, you can clearly see that it been skimmed very flat and i'd say if you measured that head it will be well below 138.20mm or even lower
Testing the future
don't know what the cylinder is liked, i haven't turned it over yet
i'm thinking of ditching the YB and putting in a n/a duratec (or similar - has anyone done an S2000 conversion?) and stripping it for a track car
Testing the future
i'll measure it up at some point and see.
don't know the cause of failure, would be interesting to hear some opinions and experiences. the car was cruising along at 70mph on the motorway in 5th, so not under load or anything. inside of exhaust manifold elbow is quite white and the spark plug for no. 4 had the nipple missing.
Get on That!
in theory yes just not as flat as that though a brand new head has no flat area and the outta rough casting can still be seen a head at 138.70mm will have a very small flat area around maybe 2-2.5mm by the looks of that head its 5-6mm at very least, you can also see the same effect around the exhaust manifold where it joins the head
i am not saying hat this is what caused this failure,but can any precautions be taking to ensure that the valve seat area does not fall out as happened in jtechs head
Indyrs
04-12-2022 12:39 PM
massivewangers
30
01-10-2015 07:40 PM
