Shock horror... Reyland Escos Tall block in bits!!
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
i believe it makes for better rod angles so makes it rev freely and with less stree but anybody feel free to correct me for being a smartarse with a lack of smart
Martin , looks like you won a trolley dash in an Aeroquip supermaket .
ive been waiting 2 years to use that line since john cross said it to me at snetterton .
Ha ha, sad I know but I was thinking of counting to see how many the car has.. Might do it tomorrow.
i hope your learning as much as you can about nos, as i said its safe if installed/set up/used right.
top of the shop things to know
(waits for the experts to add/change)
1.activation only above certain rpm 3.5k+ at a guess
2.setup in winter will mean danger in the summer
3.
4.
dam i forgot a lot since i was into it
1. Not if your running a controller
2. Set at the right pressure it should only require minor adjustments if any
3. Make sure the olives are not overtightened on anything as they close the nylon pipes up a fair bits, 2.5mm drill bit is a good way of making sure they are even.
4. Don't use 90 degree elbows on the distribution block
If you can Martin have a think about using the latest injectors a la :
Sad I know but I was thinking of counting the all today Might do it tomorrow.
Quote:
Originally Posted by Tony Ryan At least 3 Superaly racing excuses in just that 1 paragraph alone ,lol .
ALL TRUE ! LOL
watch this http://www.youtube.com/watch?v=CXBIpZx6KYk
__________________
superaly
I did notice that you waited for a bit of sport and I did try to have a play but I knew there was something horribly wrong with the front end, the steering was shaking like the wheel was about to fall off ..
give me a shout next time we meet and we will go head to head ??
hmmmm did you slip with the spanner whilst undoing the exh housing and accidently undone the head studs
Exactly that I wanted the inlet off to sort the NOS jets, I wanted the turbo off to sort turbo stuff and before I knew it the head was off too
And for all the folks (you know who you are) that said the engine would never run full boost and if it did failure would be the result.. It has and it's f@cking mint inside
How old is the engine now? ....
3.
4.
I might have stood a chance if I had knowledge of the circuit and if the NSF tyre wasn't about to pop!
fair play but ive never driven oulton in over 6 years or so and that was the first time id driven the fiesta hard,i too had a few issues to contend with,but it would have been better if it was a proper race day etc ie not having to pass on the left etc
ps check your rear bumper for orange paint , nearly ran into the back of you going up the hill towards the bridge lol
