help! what would make a cam rattly? PLEASE HELP!
Just had a high lift cam fitted! was fine for the journey home! pulled up and turned off for a max of like 20mins drive off again...and its noisey as hell
just done oil change too silkolene pros 10/50w! fully syn!
what the hell can i do?! or will it settle down?
Originally Posted by 220TC
it may just be because its new, it 'should' settle down the more miles you do.
Duncan
Duncan
and tillio! u sly git! i dont name names unless all is well!...well im off to do some miles!
Re: help! what would make a cam rattly?
foookin what?
seroiously? you saying i shouldnt run the engine at all?!fook im ment to be goin out today! Shit HELP!
Originally Posted by edd
nah puma racings a brainless knob, mine took 50-80 miles and sounded like death, then it went very quiet and was fine
why is puma racing a nob? nothing to do with the company puma racing i hope!
#1 in Spelling Club
Surely you aren't THE Puma Racing?? If so, that reply has so seriously changed my opinion of you and to think that you were on my list of people who seemed to know a bit about Ford tuning.
I would imagine that its a bit of air trapped in one of the lifters, which will clear. James, dont panic yet!! Have you tried it today?
ello
was it noisy straight away as soon as it was started it or did it start quiet then get noisy?
did they fit retaining bar back in behind the cam wheel? and is the belt tight enough for it not to jump a tooth and you could check it's still timed correctly (it's not piston contact)
cheers
Daniel
cheers
Daniel
#1 in Spelling Club
Steve, thats a bit harsh!! (about Karl I mean!!)
I have spent some time reading the information on the Puma Racing website and had quite a high opinion from what I had seen. I even considered him for headwork.
But to come out with such a firm negative diagnosis based on the very limited information provided and without seeing the car is just wrong IMO.
Ran the car today! was noisey but after 2 miles cleared right up! so gave it what its good for! then about 22miles down the road ...the tapping was back! let car cool down and all that got what i had to get done!
few hours later started the car back up!...and it was there noise! tap tap tap! real high pitch! then drove it a few miles and it went again! then just as i pulled up at home it was back! really starting to do my face in!!
Guest
Posts: n/a
sticky lifters as said if its intermitent trust me i blew a brand new piper was manufacture fault soft metal smashed lobe the car would not run at all even with that smashed lobe i had no crank damage ect did the dude run the cam in prpperly beleive its hold at 2k for a few mins?
hope ya get it sorted mate. I would say if you were truely worried about it just pop it back to where it was done, sure they will check it over to see all is well.
If that option is available to ya?
grishenko45
09-09-2015 12:58 PM
rog
04-09-2015 07:24 AM
