focus rs conversion
Old Oct 11, 2008 | 09:21 AM
ADT168's Avatar
ADT168
Default focus rs conversion
i have a 51 plate ford fiesta, and iam thinking of changing my 1.25 with a focus rs engine, does anyone know of anyone that has done this, would it be hard to do,
any info appreciated
thanks regards ashley
Old Oct 11, 2008 | 09:28 AM
alan12112's Avatar
alan12112
Focus St mk2 310 bhp :D
Jamsport did one IIRC fella
Old Oct 11, 2008 | 09:29 AM
sebspring's Avatar
sebspring
Winker
i have just finished building a frs engines 1.6 focus with a mate. we built it fro someone on here. but no idea about fiesta.
i would expcet the areas your gonna need to look at will be
driveshafts
engine mounts
steering rack/exhaust
ecu etc
is a 125 engine inlet at the front or back of the block?
Old Oct 11, 2008 | 09:34 AM
ADT168's Avatar
ADT168
front
Old Oct 11, 2008 | 11:54 AM
cjwood555's Avatar
cjwood555
Does your fiesta have mechanical or electronic clocks/dials? If mechanical you need to swap the whole car loom, IIRC. Depending on which engine managment you use of course.
Old Oct 11, 2008 | 12:44 PM
COCHYN's Avatar
COCHYN
There's a few of these knocking about, one races the Dorf recantly in Performance Ford
Old Oct 11, 2008 | 01:50 PM
AlexF's Avatar
AlexF
I asked about this recently....
Its fairly involved it seems - you planning on DIYing it?
Old Oct 11, 2008 | 02:12 PM
rathbone's Avatar
rathbone
i'm doing it at mo cus of ure engine if ure not gonna run the rs box u need to swap the bellhousing round i've used the fiesta 1800 diesel if u run the rs box u need to make a box mount and cut out some of the chassis leg to fit i.e harder engine mount is a piece of piss to make took bout a day to make ull need custom drive shafts other than that its just plumbing and fiddling round with other stuff
p.s if u use ure box after speaking to cts i think ull need atleast a s2+
liamT74
Sep 23, 2015 10:24 PM
richierich1986
Sep 18, 2015 03:29 PM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
Maxwell
Fiesta ST
Sep 13, 2015 05:31 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
