heat resistant material/board, where from?
Its probably so easy to find that I cant see it for the tree's if you know what I mean
What I'm after is the heat resistant hard fibre material in sheet form like that used for heat shields/ air filter enclosures/airbox's....tends to have an alloy looking covering to it also? Like the stuff used on the standard 2wd cossie turbo heat shields??
I'm after enclosing my induction kit then feeding it cold air from underneith the inner arch, just so you know what i'm trying to make.
Cheers,
Stu.
Cheers,
Stu.
FEATURES & BENEFITS
The Gold Reflective Film is an aerospace material capable of reflecting 78% of all radiant heat with continuous operating temperatures of 450 degrees centigrade.
The material is metalized polyamide polymer laminated glass cloth with a high temperature pressure sensitive adhesive. The film is lightweight at only 5oz per square yard, and is easy to apply and remove.
Typical applications include, but are not limited to: engine covers, side pods, suspension, under trays/floors, seat bottoms, fire walls and bulkheads.
The Minimum air gap to heat source is just 1mm.
Gold Reflective Film forms to any shape, is far more reflective with greater weight saving and is preferred over aluminized cloth and waffle board.
CONSTRUCTION: Metallized polyimide film laminated to glass cloth with high temperature acrylic adhesive protected by a release liner.
FEATURES: Excellent heat reflective characteristics and is easy to install. Withstands 675°F of radiant heat for a minimum of 8 hours.
APPLICATION: Heat reflective material used in the auto racing industry.
For further information
please contact us on:
Tel:
+44 (0) 1455 828 201 Email:
sales@clarendoneng.co.ukPROPERTY VALUE TEST METHOD:
• Thickness w/o liner .0065” +/- 10% ASTM-D-3652
• Weight w/o liner 5.04 oz / sq yd LTM 25A
• UV Stability of Adh: Excellent
• Color: Gold
• Adhesion off stainless steel 32 oz/inch of width min. ASTM-D-1000
• Shelf Life: 1 year when stored under conditions of 70 degrees F. (21 degrees C.) and 50% R.H.
• Adhesive residue removal:
Any adhesive residue remaining after removal of Gold Racing Tape can be dissolved using MEK, toluene or gasoline
• Color: Gold
Stu if you need some ally heat tape I'll give you enough to cover an airbox, make it out of some thin ally sheet and I'll drop you down some tape next time I'm back home in Derby.
Dan
Dan
Cheers for your help people but I think i'm sorted now......just construct it out of alloy, then cover it all in that sticky backed thermo barrier cloth stuff as made by the likes of thermotec etc. And to finish it off ive found some nice dzus fastners in stainless steel. I'd cut out a decent sized feed hole in the lower part of the inner wing and then run then via a suitable hose to the o/s 500 grill and secure it in place with a plastic duct from the likes of tweeks. Should look ok, better than just having the induction filter plonked in there any old way
Just need a car back from the bodyshop so I can actualy start this
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
cossie09
10-09-2015 06:56 PM
