removing long studs??
Old Oct 1, 2008 | 11:21 AM
B13 JUS's Avatar
B13 JUS
Default removing long studs??
whats the best way to remove long studs from a block as they are tight??
Old Oct 1, 2008 | 11:23 AM
B13 JUS's Avatar
B13 JUS
Old Oct 1, 2008 | 11:25 AM
B13 JUS's Avatar
B13 JUS
does any know what type of studs they are?? do arp to long studs?? because the nuts i have for them have arp on them and a 14mm socket fits them.
Old Oct 1, 2008 | 11:27 AM
St3V3_C's Avatar
St3V3_C
Can you lock 2 nuts together and use that to unscrew the stud?
Old Oct 1, 2008 | 11:30 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
As ^^^^^^^^^, double nut them and wind them out.
Steve
Old Oct 1, 2008 | 11:35 AM
B13 JUS's Avatar
B13 JUS
i've tried but the nuts are just moving and i don't want to damage the threads??
Old Oct 1, 2008 | 11:38 AM
Nash's Avatar
Nash
Cake lover!
Why do you want to remove them? If its to get machining done then get the machine shop to do it for you.
Moonstone Steve.
tighten them together then put a spanner on the bottom one and the should unwind m8.
Steve
Old Oct 1, 2008 | 11:39 AM
B13 JUS's Avatar
B13 JUS
i want the block decked
Old Oct 1, 2008 | 11:42 AM
B13 JUS's Avatar
B13 JUS
Steve
thats what i've tried mate, put the first nut upside down so the flats are together and used the spanner on the bottom nut to remove the studs.
but both nuts are just turning and not the stud. should i tighten the nuts together more or will it damage threads??
i did tighten fairly tight.
Old Oct 1, 2008 | 07:35 PM
B13 JUS's Avatar
B13 JUS
any body with any idea's?
Old Oct 1, 2008 | 07:47 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
yes tighten the nuts together more, use normal nuts and they will strip before you damage the stud as the studs a lot tougher.
Or you could, if its going to machine shop to be decked let them do it.
Dan
Old Oct 1, 2008 | 07:53 PM
B13 JUS's Avatar
B13 JUS
has any 1 used these stud before?? i think the are arp??
Old Oct 1, 2008 | 08:04 PM
SillyFezzaMk1
Rubber Rhino Crew
yes mate they widely used, and the most widely used method of removing them is to lock 2 nuts together as mentioned and undo using bottom nut, will only work if you tighten the nuts up tight.....something your not doing if theyre spinning together.
If you use a normal pair of nuts (not the ARP nuts) then they wont damage the thread at all no matter how hard you tighten them...as they'll strip well before damaging the head studs.
Get some muscle into it and they'll come off
Dan
Old Oct 1, 2008 | 08:16 PM
B13 JUS's Avatar
B13 JUS
ok thanks mate
Old Oct 1, 2008 | 08:42 PM
robbieg's Avatar
robbieg
Put a spring washer between the two nuts,or use a nyloc on the top nut.
Old Oct 10, 2008 | 01:25 AM
cossieDavedree's Avatar
cossieDavedree
then when you put them back in only finger tight the studs into block.
jessie_rs
62
Aug 6, 2019 09:27 PM
Bransby
Sep 11, 2015 01:09 AM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
hopper350
Sep 4, 2015 12:53 AM
