how to identify long studs??
is there any way of telling a engine has been long studded or they are just arp stud and nuts when the head is bolted down??
is there a part number on the nuts or something??
well, as a start, look and see if it has 6 studs and 4 std head bolts....most people only do 6 long studs
not always though you do get 10 long studs sometimes, im sure you need to mod the water pump for the, so you may spot it that way....
no there's 10 studs, supposed to be a mountune block. what's the mod to look for??
Not sure what ARP's are as I never use them. As said most UK supplied (Mountune etc) long studs have 18mm headed nuts, the type of long stud that I use does have a 17mm head but even though these are much better they not widly used.
the 18mm 1's are a pain in the tits, took me ages to grind a socket to fit then it just cracked, ended up borrowing a socket off andy gallacher, added nearly 4 hours onto the job,
wasn't very happy at all that day
sridgett
Oct 1, 2015 07:30 PM
