can someome draw me a wiring diagram please?
Old 11-09-2008, 05:40 PM
Daveysaff
Skint Passionford User
Daveysaff's Avatar
Default can someome draw me a wiring diagram please?
Not me
Anyone shed any light on which pin does what? Its a wiper relay btw
Old 11-09-2008, 06:17 PM
project rs
project rs's Avatar
out of what car
Old 11-09-2008, 06:18 PM
Daveysaff
Daveysaff's Avatar
Its a universal relay, just Hella neglected to tell me what the pins are
Old 11-09-2008, 06:27 PM
ultrav87
ultrav87's Avatar
Does it no say on the relay anywhere?
Old 11-09-2008, 06:32 PM
Daveysaff
Daveysaff's Avatar
Its a Hella 5WG 003 620-08 12V if that helps? That all thats on it.
Want to try and get the wipers sorted out tonight if I can, I'll phone Hella in the morning if no-one knows.
Old 11-09-2008, 07:48 PM
Daveysaff
Daveysaff's Avatar
btt
Old 11-09-2008, 08:04 PM
dojj
Resident Wrestling Legend
dojj's Avatar
Originally Posted by Daveysaff
Not me
there will be a feed in and out
there will be a trigger power and an earth
the one in the middle should send the trigger power to another source
the little one oin the corner i have no idea of
i've got one almost the same in the car, but it's dark out
Old 11-09-2008, 08:05 PM
dojj
dojj's Avatar
also, the is a specific way that you can tell which is which due to the pin locations and orientation, so don't get it wrong
Old 11-09-2008, 08:21 PM
Daveysaff
Daveysaff's Avatar
Thats what i'm trying to figure out, looks very similar to a vw/audi wiper relay, but still cant find any pin layouts.
Its being used with a focus stalk and wiper motor, soon as I get this done and stick a flasher unit and a couple of diodes in the flasher circuit, its done and we can go drive it
Old 11-09-2008, 08:37 PM
rssteve
rssteve's Avatar
this probably has built in timers using a capacitor. do you just want a simple on off action for your wiper?
Old 11-09-2008, 08:58 PM
Daveysaff
Daveysaff's Avatar
I'm after an intermittant, normal and fast speeds if poss.
The rep from Hella told me this relay could do it, quite possible she was talking shit just to get me to buy it though
Old 11-09-2008, 09:01 PM
cjwood555
cjwood555's Avatar
Do you have a multimeter?
Old 11-09-2008, 09:02 PM
Daveysaff
Daveysaff's Avatar
I did but its died on me
Cant get one until tomorrow now either
Old 11-09-2008, 09:04 PM
Spiky
Spiky's Avatar
google??
http://www.r1200gs.info/howto/relay.html
http://stason.org/TULARC/entertainme...ystem-IDB.html
http://www.skjagtech.co.uk/support-p...ed-wipers.html
http://www.usedcarmart.co.uk/forum/a...hp/t-7354.html
http://www.geocities.com/sprite-midget/wipers.htm
Old 12-09-2008, 06:50 AM
These are old markings now superceeded.
1 is wiper motor input + now 53 and 53e
2 is wiper brake winding now 53e
4 is wiper +, self parking switch off/also shunt winding now 53a 53b
5 is ODD are you sure it is not an "S" as it would tie in correctly and be now 49a and 53 which is (turn flasher) nb they use dual marking on some units so it saves on numbers/letters, or (as in this case) wiper motor input +
I don't have the others to hand but if you do a search of DIN 72 552 you will find the complete list, I have the manual but tucked away in garage at the mo.
Old 12-09-2008, 06:01 PM
Daveysaff
Daveysaff's Avatar
Its definitely a 5. I've been looking at some wiring diagrams today and it looks the same as whats fitted to a 98 VW Polo.
Still no closer to figuring out how to make it work with a focus stalk and motor though
Old 12-09-2008, 06:41 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
why don't you just buy a focus relay
Old 12-09-2008, 06:58 PM
Daveysaff
Daveysaff's Avatar
The std focus wipers run through a central timer that's tied into the ecu and all kinds over overly complicated shit. I've got a succession of crap switch and motor diagrams if anyone can help me out?
wiper motor
Stalk switch
and the relay again
I've only got this Hella relay to work with at the moment, but if anyone can suggest a different one that would work then feel free
Massive thanks to peeps who's posted so far, I've been ok with the loom so far, basically made it from scratch, but the wipers have flummoxed me
Old 12-09-2008, 07:02 PM
Turbosystems
Super Moderator
what a bout a sierra wiper relay
Old 12-09-2008, 07:03 PM
Daveysaff
Daveysaff's Avatar
Worth a try! Any idea on the pin outs?
Old 12-09-2008, 07:07 PM
Turbosystems
Super Moderator
not off the top of my head try googling for a diagram they are simple enough with potentiometer to vary wiper speed ,sierra ghia ,cosworth etc
Old 12-09-2008, 07:39 PM
Daveysaff
Daveysaff's Avatar
I've got an old sierra haynes kicking about somewhere, i'll have a butchers through that.
Just gotta hope the focus and sierra motors have the same inputs.
Old 14-09-2008, 03:46 PM
Daveysaff
Daveysaff's Avatar
btt
Old 16-09-2008, 06:07 PM
Daveysaff
Daveysaff's Avatar
Sussed it (or got it sussed for me!)
1=Activation(?)
2=Engine output
4=mass(earth?)
5=stop
6=wiper
8=positive
Got an e-mail from Hella in Germany today with a diagram of sorts, got to try and draw a diagram to get it to work with the focus stalk and motor now.
Feel free to PM me if you can figure it out before I can
Old 16-09-2008, 06:34 PM
focusv8
focusv8's Avatar
1=Input from Wiper switch
2=Output to wiper motor
4=Earth
5=stop {looks like some sort of feedback from the wiper motor, may not be needed}
6=To Washer motor AND from washer push button
8=Positive
It looks like this is just for wash wipe not for normal use of wipers, is that what you want it for.
Looking back at your earlier post, you're trying to replace the Focus timer unit?
My Mk1 is working without a Focus ECU attached, does yours have the later GEM unit?
Old 16-09-2008, 07:32 PM
Daveysaff
Daveysaff's Avatar
4=Earth
8=Positive
There was a GEM unit, but there was was nowhere to put the std fusebox etc, so i've re-made the entire loom. Absolute PITA to do but it fits and looks a lot better
take it 5 will be the park then?
Old 16-09-2008, 08:07 PM
focusv8
focusv8's Avatar
I've got both of mine inside the glovebox.
http://img.photobucket.com/albums/06...n/IMG_0423.jpg
Old 16-09-2008, 08:30 PM
focusv8
focusv8's Avatar
Just looking at TIS, no wonder Ford are going bust with all that wiring in and out of a GEM unit just to get a timed pulse.
Old 16-09-2008, 08:50 PM
AlexF
AlexF's Avatar
5 is regerative braking
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
THE RADMAN
19-09-2015 12:57 PM
Quick Reply: can someome draw me a wiring diagram please?
