FAO Chip/Martin etc- LS engine external dimensions?
DEYTUKURJERBS
As title really, im sure Chip knows, and Martin may well too actually.
What do they weigh too?
Also, aside from prices, I dont suppose you know if there is any advantage to a LS2 over an LS3 is there? 3s seem better all round, inc safe revs, but I dont know much about them to know if a 2 is stronger or something, only V8s I know well is Ford Windsors.
Cheers in avance
Cheers in avance
1st to 200 without NOS
Cheers in avance
Cheers in avance
With patience to search, lots of info here
http://www.ls1tech.com/forums/index.php?
Dimensions etc more likely to be found in the Conversions and Hybrids section.
As for LS1,2,3,6,7 L92 etc etc etc etc etc
Again, the info will be in there, but more important it what do you want to do with it ?
The LS2 is a perfectly good engine, as is an LS3 ( almost the same block anyway, albeit with larger bore )
DEYTUKURJERBS
Martin- I was hoping youd not need to, and thanks to Stevie, you dont! Cheers for the offer tho.
Stevie- Spot on, cheers mate
Stu- I was thinking "I wonder what an LS2 weighs, and how big they are"
Thread here, if anyone gives a damn- http://www.ls1tech.com/forums/showth...ght=dimensions
The Viper engine is too big, and in terms of power per litre......LS wins hands down.
And the LS for what it is, is bloody compact !!!
The Vette LS6 variant above, is the shortest. Water pump is pretty much same on them all, but front pulley and accessories sit 1" further back on the Vette, compared to GTO/Monaro, Camaro etc etc etc
09-10-2015 07:38 PM
