moving the b pillars back
Ford Freak
right guys im considering doing this in my focus van project .
assuming the car is a bar shell and i have all the parts required.. how much do you think it will cost to
cut out old b pillars, and weld up holes/make good,
repostion new pillars further back to accomodate the longer doors from a 2 door model ,
i dont want anything else doing behind the b pillar yet as there is a bit more work to do with the van panel etc
any ideas on a cost and who would do it?
Ford Freak
I'm guessing that you are starting with a 5 door estate shell?
It will be do-able - look at the 2 door Sapphires which, I reckon, would have a longer wheelbase. You will obviously need it done right for safety as well as looks, but I'd guess it will probably be expensive.
As it's to be a van you won't need unique side windows as you can panel them in steel but I think it could be hard to make that look "right".
if you can get the whole sides from a 2 door focus that would make it easier,that way you could cut the sills and roof pillars quite a way forward from the donor car then would cover where you took out the old pillar and would look ok as you would have the correct shape for the rear of the door aswell,also if you cut the 1/4 quite far back aswell that would give you metal to cover where the rear door used to be
that was going to be my sugestion, get yourself down a breakers and cut from just behind the wing and top of the a pillar all along the sill the just in front of the rear arch and a good way past the top of the b pillar and then weld that into the estate/van.
would be easy enough and any body shop should be willing to do that if you dont fancy doing it yourself, if you explain it that way atleast....
how would it make it harder to park as you would have longer windows using the 3 dr doors over the 5 door ones that are currently going to be used so the pillar will be futher back giving you better periferal (how ever you spell it) vision
Ford Freak
basically that is all there is to it as long as you measure and mark up on the estate/van well and carefully then you will be ahlf way there as you dont have to try to line lots of diff things up!
keeping it tidy will be the hardest bit!
this is verry doable mate but you would need 2 full sides from a 2door focus to do it properly i can do it but without seeing exactly what would be envolved i cant realy put a price on it
would you be doing filler work or would you want it done by the garage
