Group A coil +/-
Old Sep 9, 2008 | 07:54 PM
NEIL A's Avatar
NEIL A
Default Group A coil +/-
Got a mind blank while wiring up my Stack revcounter, have to connect to the - terminal so what one is it ?
Old Sep 9, 2008 | 07:57 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
It's marked on the coil is it not? Anyhow it's the green wire..
Old Sep 9, 2008 | 08:03 PM
NEIL A's Avatar
NEIL A
Cheer Martin thought it was , think its marked on the side thats tight against the header tank so thought it was easyer to ask on here.
Old Sep 9, 2008 | 08:05 PM
Martin-Hadland
You might as well use the original wire behind the clocks rather than wiring it into the bay ..
Old Sep 9, 2008 | 08:14 PM
NEIL A's Avatar
NEIL A
Very true was just going by the Stack book will check tomorrow what wire behind the dash is the signal.
Old Sep 9, 2008 | 08:18 PM
Martin-Hadland
The wire behind the dash will be fine, did one today. I would also not use the Stack speed sensor as there's a much eaisier way
Old Sep 9, 2008 | 08:29 PM
NEIL A's Avatar
NEIL A
What colour wire was it Martin if you can mind .
Already have the sensor ran just needed to make a bracket to position it behind the bell.
Old Sep 9, 2008 | 08:31 PM
Martin-Hadland
The wire is still green behind the clocks..
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
IainRS1700T
Sep 25, 2015 06:44 AM
beller
Sep 21, 2015 04:13 AM
