anyone help
anyone help
I have a water pipe split on my escort cosworth.
It is located on the plenum side
It is a black pipe under the plenum that comes off the head.
I had the AA to have a look at it they can get to the bottom of the jubilee clip but cannot get to the top. The inlet manifold is in the way.
The undone all the bolts holding the plenum on and prized it away with a crowbar but did not do it to much as they did not want to brake it,
What is holding it on after you undo the 5 bolts is it stuck on or is it on with a gasket.
can it be prized off.
hope someone can help
Thanks
Thanks
is that also with a swedish one.
i got the bottom clip off but i can not see were the top clip is to get it off as everything is in the way.
thank's
thank's
Are we talking the pipe that goes from oil modine to rear of the head under the plenum, if so you should be able to remove it without taking the inlet of although it might be tricky with a swedish plenum, the other end of the hose is just near the top of the dipstick tube.
Steve
Steve
Thanks
Thanks
never ever let anyone near your car with a crowbar!! (especially at road side )
that comes from the same draw as the sledge hammer and gas axe!
there are a row of 13mm nuts under the inlet, they are on studs that are in the inlet... so they undo towards the head.. bit tricky to get to. but not too hard..
escort mk4 cossy 4x4
the water hose at the back of the block,is on a small connecting block that has 2 allen head bolts .depending where the jubilee clip is,you can normally use a 1/4 drive socket set,with long extension.feeding by the battery/under the inlet,to get these bolts out.
bit tricky as you cant see them,but it can be done.
the warter pipe is under the first 2 injectors.
it goes from the head to the block and is inbetween the first injector gap.
i can not get to the top jubliee clip.
so do i jack the car up to get to it or do i have to take the pleum off
thanks
thanks
