zetec crank oil seals?
can these be fitted without removing the oil pump with a tool? im having a nightmare trying to get mine in and dont want to remove the pump to do it as then i have to remove the engine mount etc to do it and i have very limited space in my engine bay so wouldnt be able to fit a torque wrench down there
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
If you're talking crank pulley side - then yes - i've done a few.
Once you've taken the cambelt crank pulley off then you can just use a hook tool or a self tapper to pull the crank oil seal out then push the new one in
Oil pump doesn't need to come off!
sounds like your pushing it in too hard fella
put the top first and then try and push the bottom in its a bit hard to expalin through typing but it ends up that the bottom only needs a little bit of a tap
if this helps
if this helps
is the outer bit on the oil pump nice and clean and free from any debris fella
a few people from work even put oil or grease around the outer part of the seal to make it slid in better
i was using grease lol, i think il put it in once engine is out and accept its had its final drive in the old escort, and will next be running in my mates s2
better off that way fella incase something happened to the engine once all fitted back together
you'll be £1400 worse off then
bring it back bigger and better next time fella
least you managed to drive it fella, as most projects never ger completed just broken up
tbh mate i dont think this will be coming back, i think next car will be a bmw for track as i loved it and am not prepaired to spend roughly 12k again
grishenko45
09-09-2015 12:58 PM
