View Poll Results: T4 or Gt30
T4
![](https://passionford.com/forum/images/polls/bar2-l.gif)
![](https://passionford.com/forum/images/polls/bar2.gif)
![](https://passionford.com/forum/images/polls/bar2-r.gif)
![](https://passionford.com/forum/clear.gif)
53
36.30%
GT30
![](https://passionford.com/forum/images/polls/bar3-l.gif)
![](https://passionford.com/forum/images/polls/bar3.gif)
![](https://passionford.com/forum/images/polls/bar3-r.gif)
93
63.70%
Voters: 146. You may not vote on this poll
t4 or Gt30 for 500bhp
#281
#283
I'm not bothered who "Tony" is am i ? I was just telling you that such a twin turbo kit was available in the 1990's and it was featured in the Ford mags . If that upsets you then sorry
#285
I remember the "turbosystems" windscreen stickers on all the cossies back in the 90's . The same time as the twin turbo kit was out , shame you didn't see it in all the Ford mags
#287
#290
![](https://passionford.com/forum/images/smilies/roi.gif)
#294
And PMSL @ Tony in his pram
Tony built these cars.... seemingly from his pram
https://passionford.com/forum/general-car-related-discussion/254628-the-all-new-improved-desert-spoon-thread.html
#296
See my post above.
No-one called you a liar, I think the logic of having two smaller turbos as opposed to one large one was the reason bollocks was called. If it is so much better how come we dont see some of the very expensive cars running it today? I'm sure Martin and Rod have put lots of effort and development into their engines, yet still run single turbos
#297
DEYTUKURJERBS
RS2.7- the K gate sequential turbo thing i remember, so does most. Sequential turbos are nothing new, and easy do-able if you got the room.
The point was, what YOU were describing was utter bollocks that makes no sense to anyone with half a brain.
#298
your description of it's operation was bollox ,FYI i was involved with it's testing and development.You may have read about the twin turbo set up in a mag but don't believe the technical spec that can often be bollox.Articles are written by journalists not engine designers.
The turbo's used were a t25 not a t2 a 2wd comp wheel was grafted onto the comp end a hybrid turbo.Garret then produced this exact turbo when the eec4 escort cossie was produced.
The main area that you have read as bollox or misinterpreted is the compressor out put,these where in fact common and fed the standard inlet system.
It was not a sequential system .A special cast exhaust manifold housing the patented k gate valve was used ,cyclinders 1+3 supplied the energy to drive turbo a and cylinders 2+4 fed turbo b.At a determined boost pressure the k gate valve would open allowing all 4 cylinders to flow through both turbine housings.
The affect of this was a large drop in exhaust back pressure as exhaust flow increased.
Hope that is understandable.
#300
PassionFORD Member
Two cylinders feed each turbo (on a 4 cyl engine I'm assuming) and below a certain boost level, this is sustained BUT all the boost generated would travel through the ENTIRE inlet and not to their respective cylinders?
And after a certain level of boost reached, the K-gate valve would open and it would allow all 4 cylinders to flow through both turbines?
#306
The purpose of the development was to obtain low lag and high power,the spool up of a standard t3 with the top end of the t4,The results were more lag than a t3 but more power than a t4.The theory was quite simple two smaller turbo's combined will flow more than 1
It is extremely complex and expensive to run sequential turbos hence why they were parallel.
The toyota supra twin turbo is sequential and uses a pair of identical turbo's not one small and one large as people often think.
#310
See my post above.
#311
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
#312
![007](https://passionford.com/forum/images/smilies/bond.gif)
Shame no one on here has a "k" gate twin turbo set up with a brace of roller bearing blowers because if they did then you would see the advantages that this system would give over one big turbo
#313
#314
Colossal Pervert
#317
Happily retired
It would be nice to hear about the cars that 'out performed' everything with this twin turbo set-up. Not been around Cosworths as long as Tony but ive not heard of any achievements by these cars.
Must admit im not sure where the second GT42 would fit so I hope this dont catch on.![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
ps. Cant get the image of Tony in a pram out of my head.
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
09-10-2015 07:38 PM
