Thinking of selling the car
Ok then
What do you think i would get for my car, thinking of a change after christmas and just testing the water right now
1989, MOT till august, off the road on SORN.
80000 miles
very good body work
14000 miles on engine rebuild
Folders of reciepts
Serviced every 3000 miles
heres the spec
Engine
1618cc CVH, stage 2 big valve head (ported and polished), newman cam, solid lifters, piper vernier, wire ringed block, lowered compression, ARP conrod Bolts, heavy duty bearings, high pressure oil pump, AVA ecu, AVA modified fuel system, AVA high flow tubular manifold, T28 turbo, 360 bearing, reshaped front pipe, AVA Large capacity intercooler, samco water and boost hoses, magnecor leads, magnex exhaust, modified airbox, AP 4 paddle clutch,
Chrome
rocker cover, crossover pipe, strut tops, suspension nut covers, throttle bracket, bonnet hinges, bonnet catch, bonnet stand
Stainless steel
induction pipe, underbonnet plate, wiper motor cover, wiper motor back plate, fuse box cover, brake reservoir cover, brake reservoir cap cover, servo cover, header tank cap cover, battery cover, fuel filter cover, coil cover, lifting eyes, timing belt cover, washer bottle stopper, bailey header tank, swirl pot, oil separtor, heater box, spec-r slam panel blanks, oil cap, alternator bracket
Suspension
Koni adjustable shocks, chassis dynamic 25mm lowered springs, powerflex bushes used everywhere, stainless steel engine brace
Brakes
Front _ 300mm drilled discs with alloy bells
Rear _ Cosworth discs and calipers
Interior
factory recaro interior, momo corse steering wheel, snap off boss, momo gear knob, A/pillar mounted boost gauge, oil pressure gauge, ACT gauge, alloy handbrake and pedals, stainless sill plates
Exterior
factory rs turbo bodykit, clear front and side indicators, tinted rear lights, spec-r fuel cap, chrome badges
wheels and tyres
dare v1 7x17" alloys, 205/40 17" avon zz1 tyres
performance
205 bhp@ the wheels with 16psi boost recorded at AVA
80000 miles
very good body work
Folders of reciepts
heres the spec
Engine
Chrome
Stainless steel
Suspension
Brakes
Interior
Exterior
wheels and tyres
performance
Depends really on everyones taste, might be a bit to much bling, the main thing for me is the shell, whats that like? if its a tea bag then i agree with muska break, if its ok then about Ł4500
well mines like yours m8 but as you know im doing the underside of mine and the min i'll take when i sell mine is Ł5500 got offered that for it as it is now from a chap off this site a few months ago
mark
mark
