2 bar map on saf
Old Sep 2, 2008 | 09:38 PM
bamcossi's Avatar
bamcossi
Default 2 bar map on saf
i put up a little post to if a 3 bar will run a 2wd saf in standard form ,it doesnt .
so ive got me a brand new 2bar as was advised this is why my saf wont start i fitted it and it dont start .
im getting major stresed out with the saf now and contemplating on chucking in the towel, ive been about 6 months now trying shit loads of things and theorys .
i realy dont want to get rid as i no its not worth anything as a none runner and cant bare the thought of it being brocken up
is there any good cosworth people out there with boxes of spares that no there stuff and willing to come to my pad please i want this sorting please.
p.s. payment ,food,and plenty of tea and coffee is no problem .
thanks
Bam..
Old Sep 2, 2008 | 09:41 PM
Miller 3's Avatar
Miller 3
if i was closer i would of helped you out mate
Old Sep 2, 2008 | 09:42 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Get it up to Blackpool on the back of a trailer if you want mate - we can have a look
Old Sep 2, 2008 | 09:52 PM
bamcossi's Avatar
bamcossi
cheers you do find with this site people are very helpfull were they can be.
Old Sep 2, 2008 | 10:11 PM
bamcossi's Avatar
bamcossi
cool an excuse to go to blackpool lol on a serious note i might take you up on that if i have no joy locally can you pm a number just in case thanks Bam
Old Sep 2, 2008 | 10:15 PM
SteveH's Avatar
SteveH
Very
Very well respected guys, you could do alot worse.
And blackpool is cool
Old Sep 2, 2008 | 10:18 PM
bamcossi's Avatar
bamcossi
Originally Posted by SteveH
Very
yes blackpool is definetly cool ive got a big coat hat and gloves lol
Old Sep 2, 2008 | 10:19 PM
SteveH's Avatar
SteveH
Old Sep 2, 2008 | 10:36 PM
Jim Galbally's Avatar
Jim Galbally
call the AA and say you broke down then get it taken to blackpool. job done.
MSD will have your car running, guaranteed
Old Sep 2, 2008 | 10:37 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
What else have you changed sensor wise?
Old Sep 2, 2008 | 10:38 PM
SteveH's Avatar
SteveH
WHY HAVE I NEVER THOUGHT OF THINGS LIKE THAT????? Fair play Jim
Old Sep 2, 2008 | 10:39 PM
bamcossi's Avatar
bamcossi
im a high class painter never been intrested in the mechanical side of things till recently ,i so wished i had listend when i did my paint schooling on the 1 day a week we did mechanical .but that was in 1989 so f**k it.
Old Sep 2, 2008 | 10:40 PM
bamcossi's Avatar
bamcossi
good idea but i have the saf stripped out ready for paint when its running lol
Old Sep 2, 2008 | 10:43 PM
Jim Galbally
well unfortunately youre ina rut then as like you say you need someone who actually knows what theyre on about to havea look. someon with the right equipment and knowledge (ie an RS specialist). so it means getting the car to them on a trailer the AA are the free if you blag it
Old Sep 2, 2008 | 10:45 PM
bamcossi's Avatar
bamcossi
new phase sensor
new crank sensor
new map sensor
used ecu
3rd set of new plugs
had the injector rail off and turned it over its spirting fuel .
had rocker cover off to set timing properly making sure its not 180 out
towed it round the streets lol
swore at it
said please to it even left garage light on at night .
Old Sep 2, 2008 | 10:59 PM
CossieRich's Avatar
CossieRich
Are you getting a spark?
Old Sep 2, 2008 | 11:30 PM
Karl's Avatar
Karl
Norris Motorsport
If you're in mansfield then we are only 10 minutes away from you. We will certainly be able to sort it for you. Hope that helps in case you can't get it sorted.
Old Sep 3, 2008 | 12:14 AM
xr4x4rs's Avatar
xr4x4rs
i was just thinking tht as he hasnt mentioned it
really only 4 thing sleft to check lol
ecu
loom
coil
igntion amp
but id get it upto a specialist mate, karl or msd will both get it running in no time
Old Sep 3, 2008 | 07:56 AM
Jim Galbally
oooh, use karl then if its only 10mins away!
google "norris motorsport"
Old Sep 3, 2008 | 05:52 PM
foreigneRS's Avatar
foreigneRS
Testing the future
have you got the 2 earth leads bolted on to the inlet manifold?
Old Sep 3, 2008 | 06:14 PM
bamcossi's Avatar
bamcossi
do you do home visits or have i got to lug it over to you mate.
Old Sep 3, 2008 | 06:16 PM
bamcossi's Avatar
bamcossi
err err i think i can remember bolting wires to the inlet will check thou thanks.
Old Sep 3, 2008 | 06:20 PM
bamcossi's Avatar
bamcossi
ecu
loom
coil
igntion amp
yes got a spark a mate has also checked the leads ,ive replaced engine loom,coil twice (to make sure lol ) second hand amp from pete rs specialist,and a second hand ecu but with used parts i no theres no garantee there ok
Old Sep 3, 2008 | 06:58 PM
LHD220Turbo's Avatar
LHD220Turbo
have you had the engine apart or anything like that?
if i was closer i'd help
if not get it over to the guy Karl who posted above, his company is Norris Motorsport -
Old Sep 3, 2008 | 07:02 PM
fatmike's Avatar
fatmike
I always say this and I always will, check all the loom connections are in probably! My old cossy was being a right shit ages ago, Found one of the loom plugs wasn't connected correctly. It was one of the ones at the back of the engine which connects the engine loom into the main loom.
Old Sep 3, 2008 | 07:03 PM
bamcossi's Avatar
bamcossi
i bought the engine off ebay it was already removed but he said it was running and had just been serviced its doing my head in big time lol
Old Sep 3, 2008 | 07:19 PM
LHD220Turbo
get it over to norris if you cant sort it
mine was stood for 11 years and it took me 45 mins to get it started. We got it started with a hint of "easy start" you tried that?
Old Sep 3, 2008 | 07:38 PM
bamcossi's Avatar
bamcossi
not tried that herd they get addicted to it sounds a bit silly to me but im superstitious
DixieTheKid
11
Jun 6, 2020 11:20 AM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
