motorcraft '071' plugs
Testing the future
cheers folks, especially FletchCossie for what looks to be the finis code, which is what i need to buy them from a dealer over here.
i would buy them from mike, but probably won't see him until his easter 'ring trip as he doesn't turn up at norfolk group meets if he knows i'm coming
these plugs are for a standerd escort turbo do they really work in a cosworthlet alone a modded cosy.
I spent £80.00 on some NGK`r
i be buying these next time only £0.93 each
Testing the future
if that's the right part number, then yes, apparently they are good for tuned yb at least above stg3. that's according to mike r and stu, who both know their shit when it comes to plugs (spark plugs or butt plugs ).
can't believe they're only 93p though
Originally Posted by Stu @ M Developments
They certainly arent 93p at the dealer i buy mine from
They are a good plug, yes, but theyre certainly no NGK 9
But for the price of em you just cant go wrong really can you?
Foreigners, no worries mate I just read the box
Mike, do you know what gap should I run mine at?? Still same spec as Jason had it, if you remember? Gonna fit them over the next week or so. Cheers
Caraholic
Depends on the condition of your ignition system. Ideally you want a Grp A high energy coil and your leads to be in tip-top condition. I would then suggest that you start at 23 thou' and either open (or close) them a thou' at a time until you get to the misfire point, then back them off to the point before it started. You want the biggest gap you can run without a misfire....
I have a GpA coil already fitted with blue Ford Motorsport leads and she never missed a beat before the box went bang
Will save fitting the plugs till she's back up and running and give it a try, cheers
retail price £2.33+vat each
Originally Posted by Dave Henshall
can i just confirm that these are the ford WRC plugs?
Originally Posted by Matt
shame about the totally shite hydrocarbons you get with them though
they certainly aint no ngk9 no
Ive at least 8 cars running 0.25%co and around 90HC's with em Matt
Most of em on greys
One of em on 850CC injectors
Are you sure you didnt drop yours
well ive one car (not on closed loop ) on greys that ran huge hco's at idle with a near new set of 071's, this miraculously dropped by 2 3rds with a set of ngk9's and no other changes so yes really
deathrider666
28-09-2015 06:12 PM
