2.9 cosworth
been told that there is a better engine in the later cars and easyer to wire up is that right i was led to belive they were the same
BOB is the best and a lot of parts can still be got from Ford. I had the the BOA until the big end went and changed it for the BOB. The only problem is the BOB ecu and loom can not be used as its a pats system. I used the BOA lom and ECU. It runs fine and put out a good 220bhp and 200ft/lb
the bob has more power,(215 bhp) v boa (195bhp)
the boa is easier to wire in(5 or 6 wires iirc)
and as johnny states above you can run the bob on the boa ecu and loom.
best of both really
best of both really
its to go in a hot rod on a banger track just blown 2 2.8s at 2 meetins looking for engine options no point going down to a pinto and need to sort summin out by the 14th
could i put it on carbs ?
looking for a engine that is easy quick to fit and abuse
2.8 is well off, it only has 2 exhaust ports per head ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
you use the BOA manifolds, one of them needs a bit of bending to fit a standard 2.9 exhaust system, no drama
Why carbs? Why not throttle body fuel injection, such as a Jenvey setup?
If you do wish to run carbs, then perhaps you can use the Jenvey BOA/BOB inlet manifold (which can be purchased separately) and modify this to run bike carbs (i.e. with custom adaptor flanges). Not sure how easy this would be though, nor if there is sufficient space (between the ports and engine valley) to mount six bike carbs.
to late another 2.8 went in car is now long gone and dead
why becus it was a banger car on an oval track
Adam Graham
06-09-2015 06:04 AM
