transit speed limiter
anyone know anything about lifting the top limit? i can set and remove the 56/62/70mph limits but some have a top limit of 100mph that me of the dealer can't remove?
things that u can change, but u can change the unchangeable things by going into
asbuild data and remove speed limiter file
how do you get to that? and also where in ids do you disable the automatic locking?
that means u input or remove the data yourself, but its easy to blank the pcm and bcmi
i would pay a master tech near u to do it
u also need your van asbuild data of etis to program the pcm then u just leave auto locking and speed limiter files out
it cant swhich on that it does not know it has
reprogram modules with asbuild data only not the data stored on ids
Coldo loves seamen
Andy, there IS a master tech at ford in killie called davie stewart but hes for cars only. Theres 3 guys run the van bit at the back. I used to work in Ford, served you at the desk a few times. Anyway, the guy that could help you out with IDS is my best mate, Paul Laird. I could send you his mobile number or ask him if hed take a look out the back on the fly for you one lunchtime?
The 100mph limiter is classed as unlimited. It's there because the tyres can't take the speed and load much more than the 100mph mark (think they're rated to 108). Chipping it doesn't always remove it either. Mine is chipped but still levels out at a ton.
as Dazc said mate a chip will only get the thing faster to 100mph not really past it, and the tyre`s wont hold out for long over 105mph ( is were the limiter cuts in on mine) some one will know how to get past it though but be careful
u dont need a chip just adjust the injection pump and injectors factors with ids
SMILER258
28-09-2015 09:04 AM
