Rubber bushes on cos fuel pump bracket.....?
Can you still get these from Ford, and what is the part number????
Not the ones where it bolts to the car, but the ones inside the fuel pump/filter holder itself that hold the pump bracket on to the holder.....if you get my drift!
Just chop up an old ruber pipe and use that as cushion, don eit plenty of times works perfectly well, even used and old poly bush cut down on the bracket body bit on cozmeisters car as one was missing.
Rod-Tarry
237
18-03-2016 09:13 PM
cossie09
14-09-2015 04:21 PM
