rs2000 engine clutch probs
i fitting the lump to a fiesta just for a laugh but rather than the mtx75 going in as i have many many mountings to make i going to use b5 box like frst type. but does anyone know what clutch to use as rs2k hole in clutch is load bigger than my gearbox. Crank position sensor picks up from crank so any fly wheel can go on. Just could do with some help before i get it in car thanks all
Team HOTHOT!
best of luck putting any flywheel on - the holes in the crank for the flywheel bolts are slightly offset from each other so it will only go on in 1 position
Wilsfoci
15
30-03-2016 10:26 PM
