mounting a cps
Old Aug 26, 2008 | 04:15 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default mounting a cps
onto a box that doesn't have the hole for one?
can i just drill a hole and slot it in?
does it have to be in exactly the correct position? and not out by 1mm?
or can i get soemthing to mount it somewhere else?
Old Aug 26, 2008 | 07:16 PM
dojj's Avatar
dojj
anyone?
Old Aug 26, 2008 | 07:25 PM
sexr3i's Avatar
sexr3i
isn't it
Needs to be pretty precise, if your hole is out by 1mm it will read the TDC signals a mm sooner or a mm late. How many degrees out will that knock your timing? Can your management compensate for this? The gap between sensor and trigger is about 0.6mm too, so get it wrong and your car will misfire, not run, or end up with a CPS jammed in the flywheel - I'm assuming your flywheel has the marks for the CPS to read?
Oddkiddcreations.co.uk do trigger ring setups for cossie mgment & maybe others with brackets to mount the CPS to, but designed for a cvh. Have a look on his site and see what you can find?
Old Aug 26, 2008 | 08:37 PM
dojj's Avatar
dojj
ah
thanks for the info
it's the cps for the focus st thats mounted in the gearbox hole right at the top so i'm assuming that by moving the flywheel by x degrees i can mount the sensor that far around as well then?
maybe i should be looking at the more aftermarket kits then as i don't think there will be space in the tunnel for the mounting of the original bit in the first place
Old Sep 21, 2008 | 08:21 PM
O.K.C's Avatar
O.K.C
Eruption 101.3fm
As Sexr3i said just get a trigger designed to work.
Old Sep 22, 2008 | 01:42 PM
dojj's Avatar
dojj
looking into it further, it seems that the cps position is determined by the block, as the cps bolts onto a bracket in the head and has a hole in the bellhousing just to make it look nice
looks like i'll just have to find a suitable bellhosuing to fi the block and then put a hoe in it
DixieTheKid
11
Jun 6, 2020 11:20 AM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
