mapping
Old Aug 18, 2008 | 07:29 PM
babscossie's Avatar
babscossie
Default mapping
evening all'
1992 escos
does anyone know what most tuners would charge for a full live remap, coil pack conversion and close loop lambda conversion??
total price including everything. parts labour vat etc
cheers guys
Old Aug 18, 2008 | 07:33 PM
KSA-Cossie's Avatar
KSA-Cossie
MSD are the people to talk to m8.
picky775's Avatar
picky775
Why dont you just phone around and ask???
Old Aug 18, 2008 | 07:35 PM
babscossie's Avatar
babscossie
i'd of thought most garages are closed at this time of night
Old Aug 18, 2008 | 07:37 PM
picky775's Avatar
picky775
i meant tomorrow
Old Aug 18, 2008 | 07:43 PM
babscossie's Avatar
babscossie
really!!!!!!
Old Aug 18, 2008 | 07:47 PM
LHD220Turbo's Avatar
LHD220Turbo
evening all'
1992 escos
cheers guys
a live map alone is Ł500 approx; but they'll need your car for about 5 days
not sure about the rest; try Stu at MSD
Old Aug 18, 2008 | 07:50 PM
babscossie's Avatar
babscossie
i'm gonna give him a call tomorrow on my day off. just wanted rough ideas of prices.
Old Aug 18, 2008 | 07:55 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
deffo an msd job
Old Aug 18, 2008 | 09:07 PM
Nicole's Avatar
Nicole
"If" You need a full live map then Ł500. If not, then it may b substantially cheaper. EG: Most cars up to 400bhp are absoluely fine with just a chip to suit your spec. our 350bhp P8 chip to peak at 2bar and hold 23psi on 803 is Ł150.
Closed loop is included in those prices if you still on P8 as all our P8 calibrations have it as standard.
Wasted spark with ecu wasted spark driver is Ł550 fitted.
Only Ł400 fitted if you dont use a driver and just switch it on in the P8, but then you may have to use aftermarket tach, but we have a good solution to try first that normaly works.
Old Aug 19, 2008 | 05:32 AM
You want to seriously consider a aftermarket ecu with shed loads more features as well, as opposed to the std stuff modded, depending on how far you want to go(extra facilities) you won't be limited by the ecu then, prices can be very good as well, especially with THREE maps costing Ł275(for all three, NOT each), if you don't want to do yourself which is easy for some.
I can give you then number of someone who could do the whole job, including if wanted a new loom, with all the extras added for a later date, he makes looms for some very special people using 44 wire and 52 wire, been doing it for around 30 years.
Old Aug 19, 2008 | 06:27 AM
R5FORD's Avatar
R5FORD
still trying to change people from the dark side..
Old Aug 19, 2008 | 06:56 AM
Dingy's Avatar
Dingy
I would speak to karl at nms - No one better at doing the Level 8 LOL hey christian
and the wasted spark board for the level 8 is a bit pointless - doesn't fix the plug gap issue
Old Aug 19, 2008 | 08:25 AM
Stu @ M Developments's Avatar
PassionFords Creator
Even if that were true mate, i dont how that information is of any use to someone with an Escort Cosworth.
I bet there are fifty people on this forum running it and nobody else has a problem bar you. Not that anyone will find that unusual.
Old Aug 19, 2008 | 08:31 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Dingy
Old Aug 19, 2008 | 08:47 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
These threads really do turn into a circus
Old Aug 19, 2008 | 08:51 AM
Jim Galbally's Avatar
Jim Galbally
"plug gap issue" ?
pleae tell me that doesnt mean what i think you mean as it sounds really quite comical from n outsider's POV
Old Aug 19, 2008 | 08:58 AM
CossieRich's Avatar
CossieRich
Originally Posted by Jim Galbally
"plug gap issue" ?
Jim,
best off telling us what you think he means as cryptic messages such as yours rarely work on here.
Old Aug 19, 2008 | 09:01 AM
Jim Galbally
i suspect he's blaming a coilpack driver for not providing a strong enough spark and he's having to run a smaller plug gap than he'd like.
am i right?
Old Aug 19, 2008 | 09:10 AM
Twellsie's Avatar
Twellsie
Sorry to sound thick, but do BT escos's not run L8?
Old Aug 19, 2008 | 09:11 AM
Jim Galbally
P8
Old Aug 19, 2008 | 09:13 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
no they run p8 however an l8 will plug straight in
Old Aug 19, 2008 | 09:14 AM
CossieRich's Avatar
CossieRich
Jim,
thats what he seems to be saying mate. Everyone i know with coil packs, do run a larger gap than you would noramlly use when the standard dizzy and single coil is in use. So im not sure why Dingy is having issues
Old Aug 19, 2008 | 09:35 AM
Dingy's Avatar
Dingy
Karl has same problem with plug gaps, so did Matt Bell - sorry i don't know anyone else who has had the board fitted.
Old Aug 19, 2008 | 09:36 AM
Dingy's Avatar
Dingy
am i right?
PLug gap to stop top end missfire is less with the coil packs than with the grp a coil.
So it doesn't fix the issue IMHO
And as stu hates me then he will always have a go -
Old Aug 19, 2008 | 09:37 AM
CossieRich's Avatar
CossieRich
You have to run a small plug gap still you mean?
Old Aug 19, 2008 | 09:39 AM
Dingy's Avatar
Dingy
Yes....smaller than i ran with the grp a coil.
Ask Karl mate, he buys plenty.
CossieRich's Avatar
CossieRich
Strange - no not you, the issue
Old Aug 19, 2008 | 09:40 AM
Dingy's Avatar
Dingy
Sorry stu - i don't talk to karl about his business as its nothing to do with me.
Old Aug 19, 2008 | 09:42 AM
What version boards were they? Were they the very early ones? Were they upgraded to the later software?
We sell between 5 and 10 a week mate and have done for years, and nobody complains about spark gap. We regularly run GT30s at 0.75mm gap mate. (Although no real benefits on a YB after o.7mm)
If you want bigger than that then you need to go to coil on plug as opposed to wasted spark.
P.S: I dont HATE you at all. In fact, i dont hate anyone in this world. Life's too short. If your software is old, i will upgrade it FOC as i did with all the older boards.
Old Aug 19, 2008 | 09:56 AM
Twellsie's Avatar
Twellsie
ah. i see
Old Aug 25, 2008 | 06:34 PM
BTTT for Dingy.
Old Aug 25, 2008 | 07:01 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
........do u have to lower the gap on a bigger turbo'd car...........????........does it "blow out" so to speak........
Old Aug 26, 2008 | 05:51 PM
pete mcrash
can someone answer the above.................
Old Aug 26, 2008 | 06:04 PM
GUZZLER's Avatar
GUZZLER
it not that Stu hates you, its more like that Stu, along with most other people think that your a silly little fuckwit
Old Aug 26, 2008 | 06:07 PM
KSA-Cossie's Avatar
KSA-Cossie
Sums it up matt.
Old Aug 26, 2008 | 06:43 PM
ECU Monitor Enthusiast
LOL
Old Aug 26, 2008 | 10:12 PM
PGT's Avatar
PGT
BTTT
Old Dec 10, 2008 | 09:12 AM
The theory it "Blows Out" is a little silly, i guess it was a term made to describe it easily but its certainly nothing to do with gale force winds. lol
The actual issue is that the more cylinder pressure we run, the more voltage is required at the spark plug center electrode in order to jump the gap in the hostile environment that is a combustion chamber. So its not actually *Boost* related as such, its actually more power related which is why it tends to happen at peak torque but because more power comes with more boost and bigger turbos you can easily see and understand why the mistake is made by many people.
