mapping
Old Dec 10, 2008 | 09:22 AM
  #41
Chip's Avatar
Chip
*** Sierra RS Custard ***
Nitrous is a good "spark supressant" (trying to avoid the blow out term, lol) too!
Old Dec 10, 2008 | 09:43 AM
  #42
Turbosystems's Avatar
Turbosystems
Super Moderator
Originally Posted by Stu @ M Developments
The theory it "Blows Out" is a little silly, i guess it was a term made to describe it easily but its certainly nothing to do with gale force winds. lol
The actual issue is that the more cylinder pressure we run, the more voltage is required at the spark plug center electrode in order to jump the gap in the hostile environment that is a combustion chamber. So its not actually *Boost* related as such, its actually more power related which is why it tends to happen at peak torque but because more power comes with more boost and bigger turbos you can easily see and understand why the mistake is made by many people.
Blow Job is also a figure of speech when it is all to do with her or him depending on your sexual persuasion generating a negative pressure which then allows atmospheric pressure to create a positive pressure,which we tend to wrongly call suction
Old Dec 10, 2008 | 04:09 PM
  #43
Captain500rs's Avatar
Captain500rs
^^^^^^^ This bloke comments are mint lol
Old Dec 10, 2008 | 06:51 PM
  #44
PGT's Avatar
PGT
Hi Stu,
considering that in the std set up where the rotor arm gap is effectively 'in series' with the plug gap, is similar to the situation in wasted spark where the two plug gaps are in series (albeit one has a much lower 'resistance' given the lack of combustion pressure), why is wasted spark inherently better?
is this simply down to the greater potential dwell available to charge the coils and thus produce a higher voltage?
if so, then presumably your comment earlier about the coil on plug option is based on this time being longer again with greater potential! to address this issue?
if so, then does coil on plug offer any benfits over wasted?
sorry for the complicated question
Old Dec 10, 2008 | 08:16 PM
  #45
SiZT's Avatar
SiZT
COP allows an even higher dwell time than wasted spark because each coil fires once every 2 turns of the crankshaft as opposed to wasted spark which will fire once every turn of the crankshaft and a coil which will fire twice every turn of the crankshaft....
Think I've got that right, but may have put it across wrong
Old Dec 10, 2008 | 09:20 PM
  #46
Stu @ M Developments's Avatar
PassionFords Creator
Correct. True COP systems are not WASTED SPARK as they dont waste any at all.
Old Dec 11, 2008 | 09:15 AM
  #47
PGT's Avatar
PGT
but if wasted spark is adequate, what benefits does COP bring? Also, why is a bigger spark gap actually better than a small one?
for sure size matters in most walks of life but is 0.7mm or even 1mm better than (say) 0.5mm considering that 'a spark is a spark'?
Old Dec 11, 2008 | 05:05 PM
  #48
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
........positive, the bigger the spark the better the car feels at idel and off boost.........
Old Dec 11, 2008 | 05:11 PM
  #49
ECU Monitor Enthusiast
The more spark there is, the better the contact area with the mixture.
The more contact area, the more chance there is if hitting a fuel/oxygen mix sooner.
Dont forget, the mixture in the chamber isnt completely mixed and is moving around.
I.E. If the spark hits pure fuel or pure oxygen, it isnt going to ignite.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
jay030787
Sep 25, 2015 01:38 AM
