Transit Van Sluggish......any Ideas?
At the company i work at we have two transit vans exactly the same but one goes a lot better than the other.The slow one seems to not come on boost as early as the quicker one and makes it hard work to drive..Any ideas please
plumber mate had one same as mine real thirsty loads of black smoke when booted had new injectors new ecu etc turned out after 18mnth it was a pinhole from a stone in the intercooler,if you look very susceptable to it no protection.try get a pressure test done??
Trouble is we tow a trailer sometimes with it and its fucking useless sowe have to swap vans for a day which is a nightmare.It does leak a bit of oil from the intercooler pipes could that be a shagged turbo?
Yeah you could be right martin..I have a 2.4 rwd swb 135ps transit and its a rocket ship pulls like a train but wont rev out in 6th gear stops dead at about 3000rpm in top
mine did that when i got it. took it to ford and told them to remove the limiter. it will sit on the redline in 6th now
limited...yes kinda. if it wont rev above 3000rpm it sounds like its still in shipping mode from new. and yes as above ford can will turn this off for you. quite common you know.
As for the transit being sluggish, you really need to rev the shit out of it and double check for a split hose. if not connect to IDS (ford computer).
