help!
Old Nov 5, 2004 | 03:18 PM
rapidcossie's Avatar
rapidcossie
Default help!
have a big prob when i stat my saff from cold...it starts fine and idles ok. after a while maybe one min it will idle at two thousand rpm? will sometimes drop back down but will almost always go back up....already changed the iscv. whats next? tps?
Old Nov 5, 2004 | 03:54 PM
rapidcossie
btt
Old Nov 5, 2004 | 04:25 PM
Uncle Henry's Avatar
Uncle Henry
engine coolant temp sensor?
Old Nov 6, 2004 | 12:06 AM
rapidcossie
its fine when it heats up. the car should never idle that high, so even if the coolant temp sensor is goosed surely that would not make it idle so high?
Old Nov 6, 2004 | 12:08 AM
mark_J's Avatar
mark_J
did you replace the iscv with a second hand unit or new?
Old Nov 6, 2004 | 12:10 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
pull the plug off the iscv when u start it first thing, if revs rise then its working fine afaik, could it be the cold start comming on and when it heats up it idles proper?
Old Nov 6, 2004 | 12:30 AM
rapidcossie
replaced the iscv cos it was hunting on idle. was ok for a couple of months now doing the high idle thing. idle perfectly if you pull the plug off the iscv which was second hand when i bought it.
Old Nov 6, 2004 | 01:22 AM
jayRS's Avatar
jayRS
my wifes XR3i mk6 does this, i thnk it might be on hers that the oxygen sensors snapped off?
Old Nov 6, 2004 | 01:28 AM
vroooom ptssssh
It Wasnt Me!
maybe the iscv u got on now is fubar? i cant mind what way around it is to test em
Old Nov 6, 2004 | 10:50 AM
rapidcossie
have put my old idle valve back on and it now hunts on idle again. starting to get annoyed!!
Old Nov 6, 2004 | 11:08 AM
Uncle Henry
but has it stopped doing the silly high revs thing?
Old Nov 6, 2004 | 12:35 PM
rapidcossie
no still goes up and idles at two thousand.
did take a little bit longer b4 it did tho...about 2 mins.
fecking annoying!
Old Nov 6, 2004 | 01:30 PM
jayRS's Avatar
jayRS
my idle was a bit over the place on my FRST, when i had it tuned maty adjusted my co2 sensor thing, could yours be playing up?
Old Nov 6, 2004 | 01:33 PM
Phil's Avatar
Phil
Jeebus
Definitely sounds like 2 dodgy ISCV's!!!
Old Nov 7, 2004 | 12:57 PM
rapidcossie
think so phil!
whos got a cheap new one?
Old Nov 9, 2004 | 06:35 PM
rapidcossie
car cut out tonight after driving it for about two mins.
defo a problem when heating up cos when i eventually managed to get it started again there was loads of fuel smoke coming out of the exhaust.
does this means it had flooded itself?
ok now but when it was heating up it was running on three cylinders for a bit.
does this point to the engine temp sensor?
Old Nov 10, 2004 | 07:04 AM
rapidcossie
up
Old Nov 10, 2004 | 04:40 PM
rapidcossie
up
Old Nov 10, 2004 | 04:49 PM
boost mad's Avatar
boost mad
i had same prob and never fixed it, altho it did happen all the time! either iscv or chip
Old Nov 13, 2004 | 06:03 PM
rapidcossie
think my prob is defo coolant temp sensor but where is it on the engine?
anyone any idea of how much they are as the only one i can find is £18 but i think thats for the temp gauge on your dash.
any pics would be great!
Old Nov 14, 2004 | 12:58 PM
rapidcossie
up
