0-100 MPH??
Hopefully some of you folks might be able to shed some light on this for me.![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Mate of mine has a 3dr running a T34.48 Which was dynod @ 361bhp/353lb/ft now he told me tonight he timed himself to 0-100mph in under 10secs with so called proper timing gear, i'm not knocking him at all, BUT would it do this time even with a good launch??
seems quick to me..![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Mind you, didn't TIB do some silly times with his T34 car once??
Sub 10 is poss so long as your going for a 0-100 run... ie hold 3rd to the limiter,
The problem with a T34 is it starts to run out of puff late in the gear and most people change to 4th before 100mph so having an extra gear change in the 0-100 time.
I did get my saph into the 8's but it was running a little bit of gas at the time.
sound pretty good time to me, with my 2wd saff 340bhp also t34 i couldnt get good times at quarter mile let alone 0-100.to much wheel spin or bogged down with me.
you sure??
i sometimes changed down into 3rd at 90
![](https://passionford.com/forum/images/smilies/shocked.gif)
and mine did around 110-115 in 3rd, so staying in 3rd would be the obvious choice.
maybe you did becuase you on different gearing??? 3.9 or something?
my stage 1 at pod did 14secs to 100
I had a T34.63 and did it in 8.9 seconds.*
But it was in a fwd
with open diff though.
http://www.youtube.com/watch?v=DALWKTltrmw
Also like some1 else said, 100 on the speed is probably only 94 or something, the extra 6mph you do in 4th takes an age.
When i was having mine timed i was making sure it stopped spinning and hit the limiter in second, but it only did 58mph in second, (said 63 on the clocks)
But it was in a fwd
Here's what should be possible in theory.
Brearing in mind the 0-100 is for the slower gear change run, not the drag run.
Power at Flywheel (BHP) : 361
Weight without Driver (KG) : 1267
Power to Weight Ratio (BHP Per Ton) : 289.50
0 - 60 (Secs) : 3.68
0 - 100 (Secs) : 9.48
60 - 100 (Secs) : 5.80
Quarter Mile (Secs) : 12.32
Terminal Speed (MPH) : 114.00
Drag Strip Quarter Mile (Secs) : 11.92
Drag Strip Terminal Speed (MPH) : 117.88
How many cars do this as standard out of factory??? I was reading a article about my new car and apparently it does 0-100 in 9.1 seconds ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
regards mark
regards mark
Happily retired
Mark Syers 2wd Saff with a 400bhp MAD engine did 0-100 in 10.2 secs. This was a few years back. Mine was recorded at a Daddy Thrash 0-100 in 8.1 sec on my old 500bhp engine.
Was your saff on a T4 back then Rod??
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
