R&D 6speed
Old 08-08-2008, 10:45 AM
  #41
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Originally Posted by markk
just small adjustments mike really
I take it that is for the standard Skyline box and not the OS Giken one?
Old 08-08-2008, 10:54 AM
  #42
dumped
dumped's Avatar
I'm guessing FFD and muckle big front diff but does that much need to come out?
Old 08-08-2008, 11:04 AM
  #43
J1mbo
B1mbo
J1mbo's Avatar
hes not having a ffd i guessed that !!
Old 08-08-2008, 11:06 AM
  #44
dumped
dumped's Avatar
Oops lol
Old 08-08-2008, 11:49 AM
  #45
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
hence the huge acces panel being fitted to aid rapid and regular gearbox removal!!
Old 08-08-2008, 01:10 PM
  #46
J1mbo
B1mbo
J1mbo's Avatar
Old 08-08-2008, 01:12 PM
  #47
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
What is all the " " for? Directed at the OS Giken?
Old 08-08-2008, 01:13 PM
  #48
Franco
Franco's Avatar
Standard skyline boxes? are the comment about the front diff?
Must be a rally thang!
Old 08-08-2008, 01:16 PM
  #49
Mike Rainbird
Caraholic
Martin,
Your reading on this thread is of the same quality as Marcos .
Old 08-08-2008, 01:20 PM
  #50
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
you only need to raise the tunnel by 15mm at the gear lever,and about the same by the transfer case when fitting the r33 gearbox.
Old 08-08-2008, 01:23 PM
  #51
Martin-Hadland
Only true if fitting a std Skyline box
Old 08-08-2008, 01:26 PM
  #52
J1mbo
B1mbo
J1mbo's Avatar
does the os giken go straight in !!!???
i mean other than probs and all that ! lol
  #53
Lloyd
Lloyd's Avatar
so you cut that out for the os box? or a ffd
Old 08-08-2008, 01:28 PM
  #54
Martin-Hadland
Martin,
I can't be assed to read back!!
Old 08-08-2008, 01:30 PM
  #55
Martin-Hadland
Here's what is needed for a std & OS Giken box:
The OS Giken also needs this:
Old 08-08-2008, 01:32 PM
  #56
J1mbo
B1mbo
J1mbo's Avatar
its not toooo much work to fit em then !
Old 08-08-2008, 01:34 PM
  #57
Martin-Hadland
See post above, you can't tell the work has been done once the carpet is back in place. The gearbox bolts straight onto the YB after my belhousing has been fitted.
I may be selling my OS G as I am going to try a different gear set..
  #58
stuarth
stuarth's Avatar
will your car be on the track next sunday Martin ???
Old 08-08-2008, 01:36 PM
  #59
J1mbo
B1mbo
J1mbo's Avatar
oooh do tell more you goin for a gearbox designed for the cossie or another jap sorta thing ??
Old 08-08-2008, 01:37 PM
  #60
Martin-Hadland
No I will be in the air on the way to my hols that very day.
  #61
Martin-Hadland
Staying OS Giken
Old 08-08-2008, 01:39 PM
  #62
J1mbo
B1mbo
J1mbo's Avatar
Staying OS Giken
oh right !!
Old 08-08-2008, 01:42 PM
  #63
stuarth
stuarth's Avatar
bummer , you doing any other track days this year ?
Old 08-08-2008, 01:44 PM
  #64
J1mbo
B1mbo
J1mbo's Avatar
martoon is your ecu set to full throttle gear shift ? and does it cut the fuel or keep pouring it in ??
Old 08-08-2008, 01:48 PM
  #65
Martin-Hadland
No it isn't but that's on the cards.
Old 08-08-2008, 01:51 PM
  #66
J1mbo
B1mbo
J1mbo's Avatar
so you use the clutch to change !! bet ur lookin 4ward to that eh
Old 08-08-2008, 01:52 PM
  #67
Martin-Hadland
No, I just lift on the throttle and mash it in just like any other dog box..
Old 08-08-2008, 01:54 PM
  #68
Mike Rainbird
Caraholic
Paddle shift, like the one posted on here recently?
Old 08-08-2008, 02:00 PM
  #69
J1mbo
B1mbo
J1mbo's Avatar
oh right ! forgot bowt that lol on the old man ffd he still shows it the clutch spose its bit kinder to the box eh would love to have it converted to a 7speed sequential
Old 08-08-2008, 02:06 PM
  #70
Lloyd
Lloyd's Avatar
you mean the air shifter?
Old 08-08-2008, 02:08 PM
  #71
justin.e
justin.e's Avatar
TDP skyline has this fitted
Old 08-08-2008, 02:09 PM
  #72
Mike Rainbird
Caraholic
Yep .
Old 08-08-2008, 03:43 PM
  #73
markk
markk's Avatar
my car has been cut slightly larger than martins, but will be using the same gearbox,
oh and they dont do a 7 speed FFD sequential it has to be converted to 6 speed to get the compact drum in.
Old 08-08-2008, 05:55 PM
  #74
J1mbo
B1mbo
J1mbo's Avatar
hmmm not sure about that i was told they did but could stand corrected ??!!
i thought they did the 7speed sequential so you could have a better gearing for different things???
Old 08-08-2008, 05:59 PM
  #75
Martin-Hadland
Stand corrected!
Old 08-08-2008, 06:04 PM
  #76
J1mbo
B1mbo
J1mbo's Avatar
Stand corrected!
haha okiiii
Old 09-08-2008, 12:52 AM
  #77
markk
markk's Avatar
Stand corrected!
haha okiiii
LOL !!
Old 09-08-2008, 05:52 AM
  #78
Micky The Finn
Former Sponsor
a 7 speed FFD has no advantage over a 6 speed FFD for rallying so no need for a 7 speed sequential.
the 6 speed sequential has proved its self as bullet proof as it gets,props in abundance,gears etc off the shelf.
cannot see why you would chose anything other than an FFD gearbox for an escoz rally car mark.
Old 09-08-2008, 11:54 AM
  #79
markk
markk's Avatar
The cost of the sequential, is the only reason, if i was just having a standard 'h' pattern then there would be no contest, but the conversion to sequential from already having the 6 speed i s the price of the box again.
no other reason.
Old 09-08-2008, 12:04 PM
  #80
J1mbo
B1mbo
J1mbo's Avatar
no other reason.
can you have the skyline box so it is locked to a 50/50 split ??
Quick Reply: R&D 6speed
