R&D 6speed
Old 07-08-2008, 12:04 PM
Rippers
Monte Geek
Rippers's Avatar
Default R&D 6speed
Guys are they straight cut? dog boxes? and what power are tehy rated at?
Old 07-08-2008, 12:07 PM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Yes, yes and mine was fine at 600hp. Others have not been so lucky though.
Old 07-08-2008, 12:14 PM
andrewg
andrewg's Avatar
yip. i race/track day mine with 670hp and its fine, but you do need to be carefull with it, if you abuse it it will brake with 350
Old 07-08-2008, 12:15 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Paul,
IMO, it is not a gearbox for your lovely car . Too noisey, not nice to drive unless max attack and a bit hit and miss - fuck up a gear-change and it will cost you dearly .
Old 07-08-2008, 12:16 PM
J1mbo
B1mbo
J1mbo's Avatar
aas andrew said abuse it and you will break it the 650bhp escos in ireland broke it many a time but then justins with 520 has ben pefect for ages! all how you drive it imo
Old 07-08-2008, 12:17 PM
carlo
carlo's Avatar
Martin do you not do a box that would suit paul?
Mike Rainbird
Caraholic
I thought Paul had one - DP Engineering upgraded MT75?
Old 07-08-2008, 12:18 PM
J1mbo
B1mbo
J1mbo's Avatar
the bara box wouldnt be bad for paul would it ? still on syncros for the nice road use ??
Old 07-08-2008, 12:22 PM
andrewg
andrewg's Avatar
bara syncro for the road..
Old 07-08-2008, 12:25 PM
Rippers
Monte Geek
Rippers's Avatar
Its not that I need one at the moment.. I have the DPE box with straight cut 2nd and 3rd
I saw someone had a 6speed R&D and wondered if the 6th gear would be handy with 3.9 diffs. but didn't want a dogbox. So that's that idea screwed
Old 07-08-2008, 12:44 PM
Mike Rainbird
Caraholic
You're also forgetting the ratios . Most R&D's off the rally / race boys use a 1:1 6th gear, so like your current 4th gear is at the moment - would be lively , but what ever your maximum speed currently is in 4th gear on the DPE box, would be your maximum in 6th with the R&D, unless it was a 0.82 6th gear (which isn't the norm).
Old 07-08-2008, 02:00 PM
Rippers
Monte Geek
Rippers's Avatar
Mike you know how to kick a man whilst he is down
TBH if I blow the DPE I will seriously consider the skyline route.
Martin the figure of Ł10k floats around a lot when the skyline boxes are mentioned, is this price inclusive of a OS Giken gearbox and all the bits and pieces drive in drive out fitted?
Old 07-08-2008, 02:16 PM
Mike Rainbird
Caraholic
It's just a smidge over this for the parts, so I think you looking at just over Ł11k all in, drive in drive out .
The only issue in my opinion is the fact that I don't like the variable torque split (and the extra weight this all adds - this transmission set-up will add around 40-50kg in total to the car , so losing all the pumps etc would be a huge benfit IMO from a weight reduction and setting up the handling point of view). I've been on at Martin for ages to fit the Cossie transfer box into the Skyline casing (plenty of room), but he's not got the time or inclination .
Old 07-08-2008, 02:23 PM
Rippers
Monte Geek
Rippers's Avatar
What is modded exactly to the car? is the tunnel enlarged? the picks of matins looked like it used extra mounts etc
Old 07-08-2008, 02:37 PM
PewteRS
PewteRS's Avatar
Sell your box Paul before you blow it
Old 07-08-2008, 02:47 PM
Mike Rainbird
Caraholic
On the transmission tunnel in the offside rear passenger footwell, a panel needs a bulge putting in place, plus all the bits you can see under Martin's car .
Old 07-08-2008, 02:50 PM
Luca
Lukesville
Luca's Avatar
OT O!!!
Respray!
Old 07-08-2008, 02:54 PM
justin.e
justin.e's Avatar
Paul,
as the lads have said very good box but must be used proper....Tony has broken 2 but he'd break a crowbar in a bog
e.g missing gears will empty your bank account...in fact the only way Tony finds any gears is because their in a box..lol
Old 07-08-2008, 04:38 PM
Franco
Franco's Avatar
You fucking mental Paul! OCD OVERKILL!
IF you blow your DPE box, I'd just get a Bara box off Martoon for a fraction of the price!
(Ps wait untill I grass you up to Sadie!).
Old 07-08-2008, 04:43 PM
Rippers
Monte Geek
Rippers's Avatar
There's no need to get sadie involved now is there thats just harsh
Old 07-08-2008, 04:44 PM
Franco
Franco's Avatar
Old 07-08-2008, 04:47 PM
Rippers
Monte Geek
Rippers's Avatar
Anyway I was asking about the Skyline stuff as Chris's friend of a friends uncles brothers nieces dog gets alot of nice skyline parts cheap
Old 07-08-2008, 04:48 PM
Rippers
Monte Geek
Rippers's Avatar
ps your sig is
kitchy
RS2000 4x4
kitchy's Avatar
lloyd is selling his skyline box from his escort he is breaking maybe you could ask him about the conversion and costs?
Old 07-08-2008, 04:49 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Bara box would be a good choice. Skyline would be uber
Charlie Chalk
Unknown.
offers around 3k i think!
Old 07-08-2008, 05:01 PM
kitchy
RS2000 4x4
kitchy's Avatar
affordable
Old 07-08-2008, 05:16 PM
marco polo
marco polo's Avatar
6th gear in the r+d will be 1-1 anyway so that would be like your 4th gear in your box
you dont want a dog box for the road the novelty will so ware off
get a good syncro box you box should be ok ?
marco
Old 07-08-2008, 05:18 PM
Martin-Hadland
Not true! You can have .89 or .85
Old 07-08-2008, 05:20 PM
marco polo
marco polo's Avatar
they must come with different ratios then , thats good
the one bara had was out of a rally car his 6th was 1-1 i thought they were all the same
marco
Old 07-08-2008, 05:24 PM
Martin-Hadland
marco
The rally one's also normally come with an ultra tall 2.6 1st but mine was 2.99 ... The ratio's in my old box were spot on for road or track use.
The OS Giken comes with either .85 or .78 6th gear... I'm just about to try the taller 6th
Old 07-08-2008, 05:40 PM
capri-rs
capri-rs's Avatar
got this from R&D
Old 07-08-2008, 05:45 PM
Martin-Hadland
Originally Posted by capri-rs
got this from R&D
The ratios can be mix and matched, there is more choice than is listed.
Old 07-08-2008, 05:51 PM
sunny
sunny's Avatar
Franco you cunt! pmsl!
Old 07-08-2008, 05:52 PM
capri-rs
capri-rs's Avatar
thought so
Old 07-08-2008, 05:55 PM
marco polo
marco polo's Avatar
thats will be good you might aswell , it may defo see alot over the 200 if you can pull it
marco
NEIL A
NEIL A's Avatar
I dont find my R&D too bad to use on the road, but do find it easyer when driving hard. As Martin said above the taller 6th is nice for on the road my car cruises at 80 at around 3k rpm.
Old 07-08-2008, 07:01 PM
markk
markk's Avatar
just small adjustments mike really
Old 07-08-2008, 07:33 PM
allsteel
allsteel's Avatar
I've got the od R+D with the handbrake release centre diff.It's a super slick gearchange when youre on the attack.
Old 07-08-2008, 08:49 PM
Franco
Franco's Avatar
X
Ps Paul, my Sig rocks!
Quick Reply: R&D 6speed
