Vectra Gearboxes
Vectra Gearboxes
Anyone clued up ? Don't tell me I need to join migweb please
Took the road car out on a track day and blew the box up I was having that much fun Just gonna unbolt it and get another from the scrap yard. Scrap yard asked me do I have the code
I know nothing about Vauxhalls is it this F20 or whatever they keep going on about ? What will mine be ?
Vectra, 2000/01, Petrol, 5 speed manual
Any help as I need to do it this weekend
RWD Racer
F18 with a hydraulic clutch was the early Vectra box mk1 pre 99 and early mk2. Dont be fooled into buying an early F18 box either from a cav or astra as they are cable clutch
Later boxes do vary and may poss be a Gartrac box of some sort? CC dependent
Not sure what number that might be tho
F23?
F25?
F23?
F25?
Almost there!
Depends on the engine size, the diiferent size blocks use different gearbox's
If you look on top of the gearbox next to the gear linkage there will be the ID for it, pretty convinced it should be an F23 gearbox!
Good luck mate
Good luck mate
Got 4 on the EPC listed.
the F13, F15, F18+, and F25.
Transmission assembly F18
90522186 Final Ratio 4.18
90522185 Final Ratio 3.94
90522181 Final Ratio 3.74
90522182 Final Ratio 3.94
90522180 Final Ratio 3.57
Transmission assembly F25
90523140
Any more part numbers ya want giz a shout.!!
90523140
Its a 1.8 Vectra with hydraulic clutch AFAIK I have only lifted the bonnet once since I have owned it
Lost 5th gear which seems to have jammed it in 4th and now it wont come out of it either.
Im not phased by changing it, just need to know what to get. I suppose I will have to lift the bonnet again now
All these F numbers, don't make it a simple job do they
chowfornow
14
05-01-2019 09:01 PM
