help or advice needed regarding bmw
Team HOTHOT!
The engine management loom should be seperate like on a cossie, a big round plug near the fusebox to get it to the car loom
Just double check that the loom plug is the same pinout on the 325 loom and 318 loom as I feel there are slight differences.
i know its seperate ive fitted remember lol. the pins look the same to me the fault on my mates snap on tool came up with a code called dwa? which is the anti theft code
you snap on tool will tell you that because the car is showing that fault, the engine control isn't getting the imomobiliser code, because the ecu isn't there.. if you get me... you really need to find out what the immobiliser cuts out, fuel relay, starter relay etc.. and get round that... if you can power up your fuel pump, and starter, and have seperate power to your management you should be able to get it to run...
its not an imobiliser, its a coded ECU, he can't bypass it with some wiring
your best bet is to get the modules off the old car TBH
the old car didnt have it. and it has fuel and spark so must screw the timing or something like that ive thought about ripping the dash out and trying to remove anything ews and just using the barral and key off the old 1 failing that im going to push it in the canal because im getting to that point with the fucking car lol
i'm not trying to bypass a coded ecu with some wires... I'm sure the ecu isn't coded on early beemers.. what i was getting at is that the cars body control unit may cut the feed to the fuel and or ignition, and without the signal from the engine ecu the immobiliser willl not come off... however, if the old engine ecu and wiring is standalone, as the cossie type is, then all it should need is a live and an earth to the ecu... providing the engine has fuel and it cranks over, it should start.... the immobiliser is never going to mess with timing...
later E36s do use coded ECUs yes.
but i see what he's doing, uncoded ina coded car, in which case just do what you said and switch the stuff out!
some stuff 'talks' between body control and engine control ecus depending on what systems are used, like if the body control units works the fuel pump, it will take a signal from the engine control and other things like crash control ecus etc.. beleive me, when I worked for the AA I came across some of the most bizarre setups that have you standing at the side of the road scratching your head!!!! you'd be amazed what can be acheived with a fused length of wire!
all i'm saying is that the engine part of it, as in the bit that controls injection and sparks is on a seperate loom....thats what I meant by similar to the cossie loom... however the car in it's original state may require all of the matching bits to function properly...
e36 bmw car looms are the same some have ews some dont the ews runs into car loom which has as jim said theres a round connecter with loads of pins where you plug your engine management loom hence my saying same thing as a cossie and probably alot of other cars one of thos pins must have the ews running into it had i of changed the complete car loom(a big fooking job) i wouldnt have this problem but as im past that now i dont want to go and do that so there must be a way round it
Passion for Fords!
a cossie loom plugs into the engine sensors, plugs into the ecu, give it power and earth it runs, standalone....
your bmw loom is nothing like that, you may have canbus, or fibreoptics floating around in there as it comprises of more than one ecu i expect, the imobiliser being in one of them,
far from simple to overcome, goodluck
i really do feel the easiest way out of this is to get the remainder of the loom out of the earlier 325
the ews system is a reet fookin basitid, been there done that on a convertible i had, ews fooked up.
Passion for Fords!
it all depends how it works, it is possible its just a feed cut, or on the otherhand you may need the whole lot changed over...
try getting the two cars wiring diagrams, and compare.
i expect your older ecu is being fed coded info it doesnt understand, you need to find where this is going into the ecu, and what it needs in its place.it may be several feeds..it may even be impossible...
without diagrams im guessing tbh
Stu @ M Developments
41
21-08-2015 06:47 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
