FAO CVH Engine Builders Re: Flywheel Bolts
I renewed my flywheel/crank bolts when I last changed my clutch (around 8000 miles ago). Should they be replaced every time? or can they be reused?
They were nearly £10 last time I replaced them +a phone call to order + a trip to the Dealer..... whats the point in replacing bolts if I don't need to....??
Are they stretch bolts or not?
PassionBMW.com Member
John, just aswell you are replacing them.
We had COUNTLESS bolts fail when working in the dyno cells at work during the summer, if they are reused they have a tendancy of shearing off when you put them in and retorque them up....which is a cunt as they generally sheer flush with the crank lol.....
For a few quid......replace them!
JoeyBoyden
14
15-08-2015 09:51 PM
Gadget
13-08-2015 08:19 PM
